oxo cpu delay in dialing
vijesh up
Post by vijesh up » 25 Apr 2015 02:16
sir
i have a power cpu which runs wih version 920/41 recently i found delay in dialling all external calls through PRA & voip on digital phone
but if i remove lan connection pra is working fine.
the same system is getting restarted once in a while and in the history table it is showing mailnotifaction full but cleared all the mails but still it gets restarts with same message ( can u tell where all to see or delete mail or errors on oxo)
attaching the attachment of the same
Maulwurf
Re: oxo cpu delay in dialing
Post by Maulwurf » 25 Apr 2015 03:54
first you should try the latest patches 920/68.001. There are many corrections with voip and other bugs
vijesh up
Post by vijesh up » 28 Apr 2015 01:42
attached is the debug files and screen short of the files can any any one tell what the problem is should i upgrade the system
Return to “Hardware”
