List of incidents / List of Events, & probable cause
Post by frank » 26 Jul 2007 19:44
This document ( uncompress it with winrar, http://www.rarsoft.com ) will give you the complete list of incidents that the PBX can generate. There is also a list of Events, and their probable cause.
A must have !
unitz
Re: List of incidents / List of Events, & probable cause
Post by unitz » 14 Dec 2010 22:50
Thanks frank. That helps. :) :)
freedom
Post by freedom » 03 Jan 2011 03:49
A slightly newer file...
This contains all incidents in R8.0
R8.0_Incidents.zip
akira724
Post by akira724 » 08 May 2012 05:14
thank you
danescresa
Post by danescresa » 14 Jan 2013 02:06
do you have any for R10.1?
thanks!
Dan
alc69
Post by alc69 » 12 Mar 2013 06:55
Thank you very much !
Return to “GENERAL”
