Turn off Identity secrecy on 4028 handset - Help
DB_dbdb
Post by DB_dbdb »
We have about 1500 handsets the majority of which are the 4028 model.
We have OmniVista 8770.
My problem is I have 3 users who when they dial 9 for an outside line they get a message on the screen saying "Identity secrecy" and then their number is withheld from whoever they call.
Can someone please tell me how I turn this off?
Is it through OmniVista 8770 or do I need to type in some key combination on their handset?
I've looked all over OmniVista 8770 and can't locate how to turn off this feature.
Thanks, David
Re: Turn off Identity secrecy on 4028 handset - Help
Dial prefix - External Feature/ Secret Identity.
DB_dbdb
Post by DB_dbdb »
I'm not 100% sure how I get into Dial prefix. I can't find that section in the OmniVista 8770 software.
Thanks, David
You can create (in Translator/ Prefix plan) this prefix.
Krusty65
Post by Krusty65 »
In Omnivista go to Users/Dynamic state user/Consistant with Identity
This should be ticked for the 'Identity Secret' to be OFF (i.e for them to show there number)
DB_dbdb
Post by DB_dbdb »
Thanks for all the suggestions but none of them worked for me.
I ended up deleting the phone from Omnivista and re-creating it. It's working fine now.
sanikaroy
Post by sanikaroy »
Great Information..
fernandi
Post by fernandi »
Helpful Information!!
johnrude_91
Post by johnrude_91 »
thanks for the information.
Return to “GENERAL”
