OmniPCx Enterprise invisible in network after short period of time
Izak
Post by Izak »
Hello
I have a problem with OmniPCx Enterprise. It doesn't respond on ping, but everytime I reboot it, it works for short period of time. For like an hour everything seems to be ok, but then it doesn't respond again. Also everytime I disconnect/connect a network cable or serial, it reboots for some reason. I tried replacing CS. Connecting network cable to a different port doesn't help as well. PBx has been there for a while but this issue appeared just recently. Could it be problem on the network ?
Thanks for reply
Re: OmniPCx Enterprise invisible in network after short period of time
When you disconnect serial cable - there should not be a restart.
When you disconnect network cable - you lost link between CS and GD, GD will be restarted.
At first - check incidents on CS (incvisu command). May be you have some incidents about this problem - duplicated IP address, broadcast problem/Ethernet disabled...
Return to “GENERAL”
