802.1x and wol
plegrand
802.1x and wol
Post by plegrand » 14 Mar 2017 03:30
i'm new with 802.1x configuration and i've got a problem :
Before configuring, i used on some rooms wake on lan and it worked well.
Now i configured some switch with 802.1x mac address authentication.
I done like that :
aaa radius-server "FreeRadius" host 192.168.1.101 key my_password
aaa authentication 802.1x FreeRadius
aaa authentication mac FreeRadius
vlan port mobile 1/1-24
vlan port 1/1-24 802.1x enable
802.1x 1/1 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/2 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/3 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/4 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/5 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/6 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/7 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/8 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/9 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/10 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/11 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/12 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/13 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/14 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/15 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/16 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/17 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/18 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/19 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/20 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/21 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/22 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/23 non-supplicant policy authentication pass default-vlan fail block
802.1x 1/24 non-supplicant policy authentication pass default-vlan fail block
write memory
copy working certified
Here is the configuration result :
show configuration snapshot aaa
! AAA :
aaa radius-server "FreeRadius" host 192.168.1.101 key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa authentication 802.1x "FreeRadius"
aaa authentication mac "FreeRadius"
! PARTM :
! 802.1x :
802.1x 1/1 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/1 captive-portal session-limit 12 retry-count 3
802.1x 1/1 supp-polling retry 2
802.1x 1/1 captive-portal inactivity-logout disable
802.1x 1/1 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/1 captive-portal policy authentication pass default-vlan fail block
802.1x 1/24 direction both port-control auto quiet-period 60 tx-period 30 supp-timeout 30 server-timeout 30 max-req 2 re-authperiod 3600 no reauthentication
802.1x 1/24 captive-portal session-limit 12 retry-count 3
802.1x 1/24 supp-polling retry 2
802.1x 1/24 captive-portal inactivity-logout disable
802.1x 1/24 supplicant policy authentication pass group-mobility default-vlan fail block
802.1x 1/24 captive-portal policy authentication pass default-vlan fail block
But now obviously that does not work any more.
Is there a way with that configuration to make works wol ?
Thank you for your help and sorry for my poor english
plegrand
Re: 802.1x and wol
Post by plegrand » 14 Mar 2017 11:55
I had an answer here :
viewtopic.php?f=382&t=26990
I made some tests it seems to work.
I will confirm on the other thread
Return to “OmniSwitch 6250”
