How to remove @mac learned ?
MathieuLTP
Post by MathieuLTP » 20 Oct 2017 09:12
Hello ALl !
I try on lab to use LPS on a switch 6250.
I use these commands :
port-security 1/1 admin-status enable
port-security 1/1 maximum 1
port-security shutdown 10 convert-to-static enable
port-security 1/1 max-filtering 0
port-security 1/1 violation shutdown
It's OK to blocking port after violation.
But if i need to replace a trusted device on the port 1/1 , how can i remove @mac learned on this port and re-learn the new @mac dynamically ?
Thanks in advance.
Mathieu.
David_Klancar
Re: How to remove @mac learned ?
Post by David_Klancar » 09 Mar 2018 08:19
Hi Mathieu,
im my opinion you cannot do it dynamically, that's why it's called static...
Post by silvio » 09 Mar 2018 08:48
you can delete the static entry: port-security 1/1 no mac .....
connect the new device and convert to static: port-security convert-to-static
Return to “OmniSwitch 6250”
