I Want to see the CPU utilization
solo
Post by solo »
I've been doing some test on some 5510 and I would like to see something like the "show health" command that displays the CPU utilization. I´ve been searching for a command like that but I´ve found several commands like show processes and show memory, but none of them shows me the CPU usage.
Does anyone knows a command to see the CPU utilization on the 5510???
BR
solo
Post by solo »
I think this is one of the main problem of ALU´s data aquipment, I've been searching this info for a week and no answer from anyone in the forum and ALU´s Tech Support. Too bad
jorgehi
Post by jorgehi »
Hi Solo,
Sorry I can't help, you should open a service request.
BR.
aponterules
Post by aponterules »
Why don´t you try reading the Tech Documentation first, I think you will find what you need and more.
aponterules
Why don´t you try with the following:
"show processes"
"show memory"
but you won´t be able to find something like "show health"
Hope this info help you.
aponterules
Sorry Solo
Didn´t notice that you´ve already tried "show processes" and "show memory"
I have disucussed this issue with the expert in OmniAccess here at the local office and those where the commands he suggested.
But try to use those commands and read carefully, maybe there is the info you need
Return to “OmniAccess 5510”
