Need help with Destination NAT
chapman1507
Post by chapman1507 »
Hello, I need help with destination NAT. I want configure HTTPS access from outside to a device on the inside. But my configuration does not work. I am looking for a working config.
I have ADSL on atm0.1 as the external network and the 10.10.10.2 is the device on the inside. I used the firewall wizard and add the configuration I need.
list firewall_wiz-WAN interface atm 0.1
list firewall_wiz-RFC-1918-LIST prefix 10.0.0.0/8 prefix 172.16.0.0/12 prefix 192.168.0.0/16 prefix 0.0.0.0/8 prefix 127.0.0.0/8
match-list match_vlan1
1 ip prefix 192.168.0.0/24 any
2 ip prefix 10.10.0.0/24 any
3 ip prefix 10.20.0.0/16 any
4 ip prefix 10.10.0.0/16 any
5 ip prefix 10.30.0.0/16 any
6 ip prefix 172.25.24.0/24 any
match-list firewall_wiz-all-packets
1 ip list firewall_wiz-RFC-1918-LIST any
match-list firewall_wiz-WAN-IN-Deny-ICMP
1 icmp any any icmp-type 8
2 icmp any any icmp-type 5
3 icmp any any
match-list firewall_wiz-WAN-IN-Allow-ICMP
1 icmp any any icmp-type 0
2 icmp any any icmp-type 3
3 icmp any any icmp-type 11
match-list firewall_wiz-WAN-OUT-Deny-ICMP
1 icmp any any icmp-type 3
2 icmp any any icmp-type 11
3 icmp any any
match-list firewall_wiz-WAN-OUT-Allow-ICMP
2 icmp any any icmp-type 4
match-list firewall_wiz-WAN-IN-Deny-TCP
1 tcp any any service lt 21
2 tcp any any service eq 161
3 tcp any any service eq 162
4 tcp any any service range 600 6003
match-list firewall_wiz-WAN-IN-Deny-UDP
1 udp any any service lt 21
2 udp any any service eq 161
3 udp any any service eq 162
4 udp any any service range 600 6003
match-list firewall_wiz-WAN-IN-Allow-Mgmt
match-list match_list2
1 ip any interface atm 0.1
match-list match_https
1 tcp any interface atm 0.1 service https
! Filter Policy configuration
ip filter firewall_wiz-WAN-IN
19 match any match_https permit
20 match any firewall_wiz-WAN-IN-Deny-ICMP deny
30 match any firewall_wiz-WAN-IN-Deny-TCP deny
40 match any firewall_wiz-WAN-IN-Deny-UDP deny
50 match any firewall_wiz-WAN-IN-Allow-ICMP permit
60 match any firewall_wiz-WAN-IN-Allow-Mgmt permit
default deny
top
interface atm0.1
ip filter in firewall_wiz-WAN-IN
top
ip filter firewall_wiz-WAN-OUT
10 match any firewall_wiz-WAN-OUT-Deny-ICMP deny
20 match any firewall_wiz-WAN-OUT-Allow-ICMP permit
30 match any firewall_wiz-all-packets permit
default deny
top
interface atm0.1
ip filter out firewall_wiz-WAN-OUT
top
! NAT Policy configuration
ip nat nat_list1
10 match any match_vlan1 source-nat
top
interface atm0.1
ip nat out nat_list1
top
ip nat nat_list2
10 match any match_https destination-nat host 10.10.10.2 port 443
top
interface atm0.1
ip nat in nat_list2
ip nat statistics in
I have 3.x software on my router.
Please help me. Thanks.
Christian
Christian
I need an english upgrade
murraya
Re: Need help with Destination NAT
Post by murraya »
Hi, here is a config I have for Public interface on FE port and internal on switchport. Sorry I have not set up atm bur the general rules should be the same.
interface FastEthernet0
description WAN
ip address 121.98.115.170/30
no shutdown
top
interface Vlan10
description LAN
ip address 192.168.80.254/24
no shutdown
top
interface Vlan35
description Orcon
no shutdown
top
interface Vlan60
description lab network
ip address 192.168.60.100/24
no shutdown
top
interface Vlan1968
description callplus
ip address 10.12.80.10/24
shutdown
top
interface switchport0
switchport access vlan 10
no shutdown
top
interface switchport1
no shutdown
top
interface switchport2
shutdown
top
interface switchport3
switchport access vlan 60
switchport trunk allowed vlan 1968
no shutdown
top
interface atm0
shutdown
top
ip route 0.0.0.0/0 121.98.115.169
match-list sipout
1 udp any host 60.234.18.31 service sip
match-list teamwork
1 tcp any host 121.98.115.170 service http
2 tcp any host 121.98.115.170 service https
3 tcp any host 121.98.115.170 service 8080
ip nat Teamwork
10 match any teamwork destination-nat host 192.168.60.16 port 443
top
ip nat in Teamwork
top
ip nat oxe
20 match any sipout source-nat host 121.98.115.170 static
top
ip nat out oxe
top
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
chapman1507
At Firts. Thanks for the quick info.
I think, I had find the problem. I does not use the ip address of the outside for the match list. I use the interface name (atm 0.1) and this does not work. If I change it to the external address it works. But I have a dynamic external address. Every 24h the port reconnect and get a new IP.
So I'm still looking for a solution.
Christian
Christian
murraya
Post by murraya »
ok, so the interface in the matchlist is not reconised. is the ip@ refreshed within a range? if so maybe you could try a range i.e tcp any prefix 121.98.115.0/24 service https
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “OmniAccess 5510”
