OA 5740 R3 (alu-apps.740.3.0.0.97.0) stability?
Post by tot3nkopf » 01 May 2011 15:31
Hello everyone,
Last week I had 2 of my blackest days on technical field. The reason seems to be this equipment. I am not a data engineer however in the last 3 weeks I did my best to learn how to configure the OA. The configuration I did looks to work however if I reboot the router the forwarding engine fails with several reasons. (I encounter these kind of problems during tests but I did not take them serious --> a big mistake).
! NVRAM config last updated at 21:45:06 EEST Fri Apr 29 2011 by admin
! Statlog Configuration
logging on
logging buffered priority 7
logging buffered size 128
logging console 3
logging system 5
service timestamps log
logging rate-limit 1 10 tag SWE subtag DOS
logging rate-limit 1 10 tag PVSTD subtag PKT
logging rate-limit 1 10 tag SWE subtag SESSION
ip domain-name ifblocal
line vty exec-timeout 0 0
hostname USG
!VRF Configuration
! MULTICAST Configuration
!NOE port reservation
ip name-server 62.217.x.x
! PVST  Global configuration
modem enable
http enable
https enable
ssh enable
snmp enable
! Clock Timezone
clock timezone europe bucharest
! CWMP Configuration
! CWMP Configuration (End)
! CWMP interface configuration
! CWMP interface configuration (End)
! SNMP Configurations
snmp system location xxxx
snmp agent xcommunity xxxx
aaa services
username xxxx password xxxx
username recovery password xxxxx
interface GigabitEthernet3/0
 description WAN
 ip address x.x.151.82/30
 ip address x.x.157.22/30 secondary
 ip address x.x.157.130/29 secondary
 vrrp 1 ip x.x.157.130
 vrrp 1 ip x.x.157.131 secondary
 vrrp 1 ip x.x.157.132 secondary
 vrrp 1 ip x.x.157.133 secondary
 vrrp 1 ip x.x.157.134 secondary
 no shutdown
 top
interface GigabitEthernet3/1
 shutdown
 top
interface Vlan10
 description LAN-IFB
 ip address 10.0.0.250/24
 no shutdown
 top
interface Vlan20
 description AP-PUBLIC
 ip address 10.0.1.1/24
 no shutdown
 top
interface Vlan100
 description VoIP
 ip address 10.0.100.1/24
 no shutdown
 top
interface switchport0/0
 switchport mode trunk
 switchport hybrid native vlan 10
 switchport trunk allowed vlan 10
 no shutdown
 top
interface switchport0/1
 switchport hybrid native vlan 20
 switchport trunk allowed vlan 20
 no shutdown
 top
interface switchport0/2
 switchport hybrid native vlan 100
 switchport trunk allowed vlan 100
 no shutdown
 top
interface switchport0/3
 switchport mode hybrid
 switchport hybrid native vlan 123
 no shutdown
 top
interface switchport0/4
 shutdown
 top
interface switchport0/5
 shutdown
 top
interface switchport0/6
 shutdown
 top
interface switchport0/7
 no shutdown
 top
interface Tunnel1
 ip address 172.16.0.2/24
 tunnel source 192.168.0.220
 tunnel destination 192.168.0.80
 mode gre
 tunnel df-bit clear
 no shutdown
 top
ip route 0.0.0.0/0 GigabitEthernet 3/0 x.x.151.81
ip route 10.0.200.0/24 Tunnel 1
match-list Internet
1 ip any any
match-list vlan10xxxx
1 ip prefix 10.0.0.0/24 prefix 10.0.200.0/24
match-list WAN-IN-Carthame
1 tcp any host x.x.157.130 service eq 443
2 tcp any host x.x.157.130 service eq 8180
3 tcp any host x.x.157.130 service eq 8443
4 tcp any host x.x.157.130 service eq 3389
match-list WAN-IN-CarthameWEB
1 tcp any host x.x.157.131 service eq 80
2 tcp any host x.x.157.131 service eq 3389
match-list WAN-IN-S01
1 tcp any host x.x.157.132 service eq 3389
match-list WAN-IN-S02
1 tcp any host x.x.151.82 service eq 3389
match-list PetreIN
1 tcp any host x.x.151.82 service eq 50007
match-list Carthame-SNAT
1 ip host 10.0.0.2 any
match-list CarthameWEB-SNAT
1 ip host 10.0.0.4 any
match-list AP-Public-SNAT
1 ip prefix 10.0.1.0/24 any
match-list WAN-IN-Mail
1 tcp interface GigabitEthernet 3/0 host x.x.151.82 service eq 22
2 tcp interface GigabitEthernet 3/0 host x.x.151.82 service eq 25
3 tcp interface GigabitEthernet 3/0 host x.x.151.82 service eq 995
match-list S01-SNAT
1 ip host 10.0.0.1 any
match-list forbid25
1 tcp any any service eq 25
match-list allow25
1 tcp host 10.0.0.6 any service eq 25
match-list forbidvlan
1 ip prefix 10.0.0.0/24 prefix 10.0.1.0/24
2 ip prefix 10.0.100.0/24 prefix 10.0.1.0/24
! Filter Policy configuration
ip filter Port25
   1 match any allow25 permit log
   2 match any forbid25 deny log
   default permit
top
  ip filter out Port25
top
ip filter vlan10-100deny
   1 match any forbidvlan deny log
   default permit
top
interface Vlan20
  ip filter out vlan10-100deny
top
! NAT Policy configuration
ip nat WAN-IN
   110 match any WAN-IN-S02 destination-nat host 10.0.0.5
   140 match any PetreIN destination-nat host 10.0.0.86
   150 match any WAN-IN-Carthame destination-nat host 10.0.0.2
   160 match any WAN-IN-CarthameWEB destination-nat host 10.0.0.4
   170 match any WAN-IN-Mail destination-nat host 10.0.0.6
   190 match any WAN-IN-S01 destination-nat host 10.0.0.1
top
  ip nat in WAN-IN
top
ip nat Internet
   40 match any Carthame-SNAT source-nat host x.x.157.130
   50 match any CarthameWEB-SNAT source-nat host x.x.157.131
   60 match any AP-Public-SNAT source-nat host x.x.157.22
   70 match any S01-SNAT source-nat host x.x.157.132
   210 match any Internet source-nat host x.x.151.82
top
  ip nat out Internet
top
! Dos attack configuration
! System doesn't have IDS License
! IDS configuration may not be effective
!Snort configuration
firewall
  intrusion snort
top
! Firewall configuration
! IPSEC License installed
! IPSEC Policy configuration
crypto ike key xxx peer 192.168.0.80
crypto ike dpd interval 300 timeout 1500
crypto ipsec transform-set myset esp-md5-3des
crypto map xxxx ipsec-ike default
	peer 192.168.0.80
	match vlan10xxxx
	transform-set default
	pfs group2
! Applied to : GigabitEthernet3/0
	crypto map xxxx
top
crypto ipsec profile pv
	pfs group5
	lifetime seconds 28800
	lifetime kilobytes 28800
! Applied to:
interface Tunnel1
	ipsec-profile pv
top
! No client object Defined
! No client profile Defined!
!QoS Configuration
!DDNS configurations
top
top
! IP-Policy configuration
ip-policy PBR-IFB
    10 match any S01-SNAT next-hop x.x.157.129
    20 match any Carthame-SNAT next-hop x.x.157.129
    30 match any CarthameWEB-SNAT next-hop x.x.157.129
    40 match any AP-Public-SNAT next-hop x.x.157.21
exit
    ip-policy PBR-IFB
exit
!Customized-Services
top
! DHCP Server Configuration
service dhcp enable
ip dhcp pool p20
network 10.0.1.0 255.255.255.0
range 10.0.1.100 10.0.1.200
 option routers 10.0.1.1
 option dns-server x.x.193.1 primary
top
! DHCP CLIENT Configuration
ip dhcp client default_client
vendor-class-identifier FDC broadband-forum.org
parameter-req-list vendor-specific
top
top
top
top
!OAM Configuration
oam
top
!NHRP configurations
top
! DHCP Relay configuration
end
At this point (initial configuration) all the things work w/o visible issues.
The reason for using vrrp is that we cannot add in other way (as secondary address for example) that range of external IP's (or at least we didn't figure a way to do it).
Errors on reboot:
sername :2011 Apr 29 20:50:08: %SWE-3-ARPD: VRF ADD Notification with vrfid 0
2011 Apr 29 20:50:10: %NAT-3-NAT-FS: IP Address/Ports used in SNAT policy is overlapping with DNAT addresses/ports. Please use different IP/Ports in either of the policies.
2011 Apr 29 20:50:10: %NAT-2-LOG: IP Address/Ports used in DNAT matchlist is overlapping with SNAT. Corresponding SNAT sessions will be deleted.
2011 Apr 29 20:50:11: %CE-2-LOG: Setting gre for_us node 32 default to 7
2011 Apr 29 20:50:11: %SWE-2-GRE: For us node 32 default 7
2011 Apr 29 20:50:11: %NAT-2-LOG: IP Address/Ports used in DNAT matchlist is overlapping with SNAT. Corresponding SNAT sessions will be deleted.
2011 Apr 29 20:50:12: %NAT-3-NAT-FS: IP Address/Ports used in SNAT policy is overlapping with DNAT addresses/ports. Please use different IP/Ports in either of the policies.
2011 Apr 29 20:50:20: %CE-2-LOG: Setting gre for_us node 32 default to 7
2011 Apr 29 20:50:20: %SWE-2-GRE: For us node 32 default 7
2011 Apr 29 20:50:20: %SWE-3-ARPD: VRF ADD Notification with vrfid 0
2011 Apr 29 20:50:24: %NAT-3-NAT-FS: IP Address/Ports used in SNAT policy is overlapping with DNAT addresses/ports. Please use different IP/Ports in either of the policies.
2011 Apr 29 20:50:24: %NAT-2-LOG: IP Address/Ports used in DNAT matchlist is overlapping with SNAT. Corresponding SNAT sessions will be deleted.
2011 Apr 29 20:50:26: %NAT-2-LOG: IP Address/Ports used in DNAT matchlist is overlapping with SNAT. Corresponding SNAT sessions will be deleted.
2011 Apr 29 20:50:27: %NAT-3-NAT-FS: IP Address/Ports used in SNAT policy is overlapping with DNAT addresses/ports. Please use different IP/Ports in either of the policies.
When trying to ping any interface ip---> Fail to connect to forwarding engine. Nothing works anymore (the interfaces are no longer up :shock: ).
In this point I have to detach all policies from Giga interface, reboot, reatach one by one the policies.....
Is this a configuration problem? A bug? Both?
Any help on this guys?
(Murray, Benny?)
Any help is appreciated. Other comments regarding overall experience with OA5510, 5740 also appreciated.
Re: OA 5740 R3 (alu-apps.740.3.0.0.97.0) stability?
Post by tot3nkopf » 15 Jun 2011 03:06
:) I forgot about this post. late but here is the result:
-this was a configuration problem -->we misconfigured a VRRP (there was no point in configuring such thing in our case) -->this led to engine crush
-support was very bad: I have opened an eSR-->no response for 2 days, then they asked for tech file, which I have provided; in the mean time I have solved a port overlapp problem for nat and snat-->updated the status on eSR that that problem is solved but system still crashes-->guess what the reply was after10 days-->that they saw a problem with overlapping ports for snat and dnat on my config (so they responded with the update I have previously made :shock: :shock: :shock: )--->nothing about VRRP config ; solved the proble and left the eSR raised just as I was curious-->after few more days they asked if they can close the eSR as the issue was already replied :shock:
So gents --> not the best support
However the equipment does it's job w/o issues since it's installation and looks like a good solution if you play enough with it (I think that an educated networking person will have no problem with it --> very Cisco like)
Return to “OmniAccess 5740/5780”
