[Ques] How to manage all switches in this topology?
dangkita
Post by dangkita »
Dear all,
I downloaded this topology in the internet and wonder how we can manage all switches in this topo?
As far as i know, we will only manage 2 switches: 9700 and 6850B that have management vlan in this topo, right?
Configuration of switches are in file below.
Thanks.
cedric1
Post by cedric1 »
hello
It is the case, Omnivista is only able to manage 2 switches : 9700 and 6850B via management vlan.
In this scenario, 6850A & C are customer switches, so not under Provider responsability.
We don't care about op and vlan coming through client switches.
Cedric
dangkita
Post by dangkita »
Thanks Cedric for ur reply.
But if i have to manage all of them, does it have any way to do this?
cedric1
Post by cedric1 »
hello
Yes you can do it :
1- extend management svlan - best solution
2- go through routing to an ip interface on the CPE
dangkita
Post by dangkita »
Hi Cedric,
1- How could we extend Management svlan? Could it be done in newest version: 6.4.3?
2- I dont really understand ur sollution. Could u pls take more detail?
Abismail
Re: [Ques] How to manage all switches in this topology?
Post by Abismail »
Hi Cedric,
Can you please give me the procedure to add a switch in OmniVista 2500, I am a beginner in the world DATA.
Best regards,
Return to “OmniVista 2500/2700 v3.4 and older”
