We support GIXEN, the eBay sniper.
Best Buy Co, Inc.
OS 9700 AND OS 6850 AOS , MINIBOOT UBOOT UPGRADATION.
Use this forum ONLY for website related issues.
Do NOT use this forum for your phone system or data gear issue.
ram
Post by ram » 18 Oct 2011 00:29
Hi ,
This is ram from India. I am New to alcatel product. actually i want to upgrade all the switches To 6.4.3.779 and uboot 6.3.4.265 .As of now in 9700switch i m having Aos 6.1.5.479.r01 and uboot will be 6.1.5.354.r01 and in 6850 switches Aos release 6.3.1.871.R01 and uboot will be 6.1.3.R01 and some other 6850 switches have Aos 6.1.3.719.R01 and uboot 6.1.3.601.R01. Please someone help me on this scenario.
Ram
one6f
Re: OS 9700 AND OS 6850 AOS , MINIBOOT UBOOT UPGRADATION.
Post by one6f » 18 Oct 2011 05:53
Hi ram,
please refer to the Upgrade/Downgrade Matrix in 6.4.3.R01 Upgrade Instructions and AOS 6.3.4.R01 Upgrade Instructions for software compatibility when upgrading !!!!!
9700:
Step 1
6.1.5.479.R01->6.3.4.R01 GA
6.1.5.354.R02->6.3.4.265.R01
Step 2
6.3.4.R01 GA->6.4.3.R01 GA
6850:
Step 1
6.1.3.719.R01->6.3.4.R01 GA
6.1.3.601.R01->6.3.4.265.R01
Step 2
If you are upgrading the U-boot and Miniboot, you MUST complete the image file upgrade BEFORE upgrading the U-Boot and Miniboot files.
Please note:
To use the USB Feature, you must upgrade to U-Boot/Miniboot version 6.4.3.479.R01.
Last Maintenance Release is 6.4.3.810 R01.
ram
Post by ram » 19 Oct 2011 05:47
Hi one6f,
Thanks a lot for ur reply. one more thing how to upgrade aos and miniboot in ftp please tell me the proper steps as well as commands. because i read the document i didnt get proper idea in cli mode so please help me how to upgrade the aos and miniboot.
ram
Post by ram » 25 Oct 2011 01:26
Please anyone help me on this because we are having this activity on friday .
one6f
Post by one6f » 25 Oct 2011 13:33
I assume you have not any OmniVista installed, it's pretty simple to upgrade AOS Switches using OV,else try this and this.
If you prefer cli approach here you find Ftp baby steps from workstation to switch by generic upgrade.
Before ftp you need probably aaa authentication ftp local on your AOS switches.
Image files must be placed in /flash/working!
Upgrading steps described in detail in attached docs. Follow is an output:
Upgrading the Image Files
Follow the steps below to upgrade the image files to 6.3.4.R01.
1 Download the 6.3.4.R01 upgrade files from the Alcatel-Lucent Service and Support web site to your PC.
2 FTP the following 6.3.4.R01 image files to the /flash/working directory of the primary switch: K2os.img, Kadvrout.img, Kbase.img, Keni.img, Ksecu.img.
3 Log into the switch. In dual redundant configurations you must log into the primary switch. 4 Reload the switch from the working directory.
-> reload working no rollback-timeout
YOU NEED EXACTLY KNOW WHAT ARE YOU DOING, IT MAY BE NOT SO GOOD FOR YOUR DEVICE!
ram
Post by ram » 27 Oct 2011 01:20
Hi One6f,
Thanks for ur reply. In omni switch 6850 stacking please let me know how to upgrade the miniboot from 6.1.3 to 6.3.4.265.
As of now im having my Aos release will be 6.3.1.601.R01 and uboot Version Will be 6.1.3.601.R01. Is it possible to do upgradating the uboot in stacking...?
one6f
Post by one6f » 27 Oct 2011 05:32
if you wish to update from 6.1.3 to 6.3.1 consult this Techtip. For stack needed:
update backup miniboot all
update default miniboot all
update bootrom all
[/size]But you wish to know how to upgrade the miniboot from 6.1.3 to 6.3.4.265.
So in early attached 6850_rel6_3_4_r01_upgrade.pdf you can find on site 14:
To verify that the NI modules were successfully upgraded, use the show ni as shown on site 17-18 or show ni 2 for slot 2.
ram
Post by ram » 28 Oct 2011 00:13
Hi one6f,
Today evening im having this activity i read the document i have one doubt on this i.e using ftp i have uploaded the ku-boot.bin and kminiboot.uboot files in flash directory .once i uploaded successfully in console i have to use this command that is update uboot-miniboot.after that before going to reload working command the document said need to delete uboot and miniboot files in flash directory.the thing which file(i.e filename) i have to delete in flash. Please reply asap.i need your help on this .
one6f
Post by one6f » 28 Oct 2011 02:46
Hi ram,
listing /flash directory:
ls /flash
You should see ku-boot.bin and kminiboot.uboot
Simple remove these if update successfully completed:
rm /flash/ku-boot.bin
rm /flash/kminiboot.uboot
Then reload the switch:
ram
Post by ram » 28 Oct 2011 03:20
Hi one6f,
Really thanks a lot man, update uboot-miniboot command is enough to update the flash in stack...?
This is what im going to do for today activity please rectify if im going to do any mistake in the below.
in 6850 stack switches.
step1) ftp the switch ip
step2)login the switch using telnet, Current Aos is 6.3.1 , uboot is 6.1.3.so first im going to upgrade aos from 6.3.1 to 6.3.4
step3)ftp cd/flash/working
Step4)create the local directory
step5)mput *.img
step 6)in telnet using reload working no roll back-timeout.
step7)once reload the switch check the network it was woking fine working mode if its working fine means i will go for copy working certified flash-synchro.
Step8)again ftp cd/flash
step 9)mput *.bin
step 10)mput kminiboot.uboot
step 11) in console put the command update uboot-miniboot
step 12)once update completed
step 13) ftp cd/flash
step 14) ls
step 15)rm /flash/ku-boot.bin
step 16)rm /flash/kminiboot.uboot
step 17)in console reload working no rollback-timeout.
please help me this what im going to do if i did any mistake on this please rectify it will be really helpful .kindly do the needfull
Locked
Return to “Talk to the admins”
Who is online
Users browsing this forum: No registered users and 1 guest
