Problem: MAO is locked
Use this forum ONLY for website related issues.
Do NOT use this forum for your phone system or data gear issue.
Eng Ayoop
Post by Eng Ayoop » 28 Nov 2011 05:48
When I try to review and modify Users, trunk groups or ....., I got this error:
┌─Error:────────────────────────────────────────────────────────────────────┐
│ Press CANCEL to remove this window
│ processing Failure
│ OBJECT -1: ATTRIBUTE 0: MAO is locked ( either mao off or locked by ACD )
How to unlock it?
Re: Problem: MAO is locked
Post by vad » 28 Nov 2011 06:13
play with "mao" command.
this command show mao, broadcast state etc.
Post by frank » 28 Nov 2011 16:49
Most of the time, this happens because either the system is doing a backup, or because it was doing a backup and got interrupted while doing it.
If you do not want to reboot, as Vad said, try "mao on" for example, or some other commands.
Let us know if it worked for you.
Eliott
Post by Eliott » 29 Nov 2011 01:59
Check state with mao -a
MAO is off by MASTERCOPY => mao -mastercopy
MAO is off => mao on
mao -mastercopy could be useful when a mastercopy fails and mao is still off (because mao on doesn't work in this case...)
Eng Ayoop
Post by Eng Ayoop » 29 Nov 2011 04:00
Thanks for all of you :)
I have tried all mao commands and mao -mastercopy, but it didn't help :(
In fact, I restarted the PBX since 3 weeks ago to change the time zone, and I could access users and trunk groups next day. But I don't know what happened after that???? Since one week I get just this error message.
Eliott
Post by Eliott » 29 Nov 2011 04:07
Did you test mao -duplication ? (CPU Redundancy)
What does mao -a has shown? (If you remember it...)
Eng Ayoop
Post by Eng Ayoop » 29 Nov 2011 04:35
Here is the result of mao activity command( mao -a ):
BROADCAST is off by DUPLICATION
MAOAGENT running process 0
MAO is off by DUPLICATION
MAO trace : off
Trace on BRODCAST is off
Synchronization 4400-47xx is on
Also ( mao -duplication ) result is:
DUPLICATION is off
Eliott
Post by Eliott » 29 Nov 2011 04:52
Yeah.
mao +duplication
And solved :)
(I mistyped it in my first posting + not -)
mustafa.ahmad
Post by mustafa.ahmad » 29 Nov 2011 04:59
enter this command "mao on"
Hope this will help you.
Eng Ayoop
Post by Eng Ayoop » 29 Nov 2011 05:20
Thanks to all who tried to help :)
Eliott: It was perfect.
mao +duplication was the solution :)
Locked
Return to “Talk to the admins”
