Testimonials section
Use this forum ONLY for website related issues.
Do NOT use this forum for your phone system or data gear issue.
Locked
Eliott
Post by Eliott » 07 Dec 2011 02:31
Hi, the testimonials section on the top is a litte too big.
You don't think so?
Is it not possible to put it in the header instead?
Or give a chance to disable / hide it?
Re: Testimonials section
Post by frank » 08 Dec 2011 21:26
Is this how you see it ?
Maybe I should remove it.
I'm just trying to generate some $$ with this, since times are hard around here .... :)
Eliott
Post by Eliott » 09 Dec 2011 03:52
It's okay but not too big.
The screenshot is as I expect it. (Request)
I see is as shown below
Locked
Return to “Talk to the admins”
