Mitel -DPNSS call disconnect every 3 min
Use this forum ONLY for website related issues.
Do NOT use this forum for your phone system or data gear issue.
Locked
prasanna_s3
Post by prasanna_s3 » 12 Feb 2012 11:04
We have 2 oxe node with full hybrid, one of the node is conected to mitel system by using DPNSS trunk.
Our problem is
Node 1 <-----ABCF ------> Node 2< ------DPNSS --------> Mitel
if the Node 2 user call - mitel user the calls are ok
If the Node 1 user call - Mitel user the call is disconnect every 3 min- strange issue
any one tell me why this happening???????????
if mitel user call node1 or node 2 user, the calls are ok
Re: Mitel -DPNSS call disconnect every 3 min
Post by tot3nkopf » 12 Feb 2012 14:52
Traces?
Post by vad » 12 Feb 2012 22:22
In trunk group - declared special services=timed call release?
prasanna_s3
Post by prasanna_s3 » 13 Feb 2012 04:40
if it is there it should get disconnect for all the nodes....it is not specified our case
Post by vad » 13 Feb 2012 06:01
prasanna_s3 wrote:In trunk group - declared special services=timed call release
Not for ALL nodes, ONLY for user with phone feature COS where declared "rights timed call release=true".
At first - check with "t3" trace:
- you have disconnect from Node 2 or Mitel?
- if node 1 user call - when Mitel user answer - you have CONNECT message, send or not CONNECT ACK message node 2 (to Mitel).
prasanna_s3
Post by prasanna_s3 » 13 Feb 2012 06:36
Node 2 to DPNSS -we can not take t3 for DPNSS trunk( trt2 trace only work)
Node 1 to Node2 is vpn trace only will come,
so please let me know how to take the trace....
Post by vad » 13 Feb 2012 06:50
Compare trt2 trace for node1-mitel and node2-mitel calls (at first).
Next - make vpn trace (for node1-mitel calls) - may be you have problem with connection/connection ack.
prasanna_s3
Post by prasanna_s3 » 14 Feb 2012 23:25
Today I observed that during the conversation, sometime no speech .strange issue
Post by vad » 14 Feb 2012 23:33
No speech, where? Node1-2? Both direction or 1 way speech?
Some problem with RTP flow.
Locked
Return to “Talk to the admins”
