6850 bad crc error
Use this forum ONLY for website related issues.
Do NOT use this forum for your phone system or data gear issue.
Locked
Dsco
6850 bad crc error
Post by Dsco » 06 Mar 2012 14:34
Need help plz.......
boot0
U-Boot 1.1.0(6.1.3.601.R01) (Sep 13 2006 - 14:37:19)
MPC8248 Reset Status: External Soft, External Hard
MPC8248 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8248 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel OS68xx (Kite II)
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
No environment variables found, using defaults
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
Device 0: Model: CF 64MB Firm: 06/07/29 Ser#: GHS3ABPCF07112100004
Type: Removable Hard Disk
Capacity: 62.5 MB = 0.0 GB (128000 x 512)
USB: scanning bus for devices...
USB device not responding, giving up (status=80000000)
0 USB Devices found
Hit any key to stop autoboot: 0
## Booting image at ff900000 ...
Image Name: miniboot-6.1.3.601.R01
Image Type: PowerPC VxWorks Kernel Image (gzip compressed)
Data Size: 781716 Bytes = 763.4 kB
Load Address: 00005000
Entry Point: 00005000
Verifying Checksum ... Bad Data CRC
=> help
? - alias for 'help'
autoscr - run script from memory
base - print or set address offset
bdinfo - print Board Info structure
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm - boot application image from memory
bootp - boot image via network using BootP/TFTP protocol
bootvx - Boot vxWorks from an ELF image
cmp - memory compare
coninfo - print console devices and informations
cp - memory copy
crc32 - checksum calculation
diskboot- boot from IDE device
echo - echo args to console
erase - erase FLASH memory
fatdelete - delete a file from a fat filesystem
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fatwrite - write binary file to a fat filesystem
flinfo - print FLASH memory information
go - start application at address 'addr'
help - print online help
icrc32 - checksum calculation
ide - IDE sub-system
iloop - infinite loop on address range
imd - i2c memory display
iminfo - print header information for application image
imls - list all images found in flash
imm - i2c memory modify (auto-incrementing)
imw - memory write (fill)
inm - memory modify (constant address)
iprobe - probe to discover valid I2C chip addresses
itest - return true/false on integer compare
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
md - memory display
mm - memory modify (auto-incrementing)
mtest - simple RAM test
nfs - boot image via network using NFS protocol
pci - list and access PCI Configuraton Space
printenv- print environment variables
protect - enable or disable FLASH write protection
rarpboot- boot image via network using RARP/TFTP protocol
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
sleep - delay execution for some time
tftpboot- boot image via network using TFTP protocol
usb - USB sub-system
usbboot - boot from USB device
version - print monitor version
=> printenv
bootargs=
bootcmd=run miniboot
bootdelay=1
baudrate=9600
loads_echo=1
ipaddr=192.168.10.1
serverip=
rootpath=
gatewayip=
netmask=255.255.255.0
hostname=OS68xx
bootfile=
loadaddr=0x1000000
stdin=serial
stdout=serial
stderr=serial
miniboot=bootm 0xff900000
osboot=run miniboot
bootflags=0x0
serialmode=modemControlOff
Environment size: 316/8188 bytes
=> setenv baudrate 115200
\## Switch baudrate to 115200 bps and press ENTER ...
AFTER THIS POINT SWITCH FREEZ .....CAN'T DO ANY THING
=> run miniboot
No ethernet found.
IDE: Bus 0: OK
0 USB Devices found
Hit any key to stop autoboot: 0 =>
=> run miniboot
=> boot
=> version
- pci_clk 66666666
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
0 USB Devices found
=> printenv
bootargs=
bootdelay=1
baudrate=9600
loads_echo=1
ipaddr=192.168.10.1
serverip=
rootpath=
gatewayip=
hostname=OS68xx
bootfile=
loadaddr=0x1000000
stdin=serial
stdout=serial
stderr=serial
osboot=run miniboot
bootflags=0x0
=> setenv bootflags 0x1000
=> printenv
bootargs=
bootdelay=1
baudrate=9600
loads_echo=1
ipaddr=192.168.10.1
serverip=
rootpath=
gatewayip=
hostname=OS68xx
bootfile=
loadaddr=0x1000000
stdin=serial
stdout=serial
stderr=serial
osboot=run miniboot
bootflags=0x1000
Environment size: 319/8188 bytes
=> saveenv
done
Protected 2 sectors
=> run miniboot
=> mtest
Pattern 00000000 Writing...
CLI --- FREEZE THEN (CANNOT DO ANY THING)
=> coninfo
List of available devices:
serial 80000003 SIO stdin stdout stderr
=> bdinfo
memstart = 0x00000000
memsize = 0x10000000
flashstart = 0xFF800000
flashsize = 0x00800000
flashoffset = 0x00000000
sramstart = 0x00000000
sramsize = 0x00000000
immr_base = 0xF0000000
bootflags = 0x00000001
vco = 400 MHz
sccfreq = 100 MHz
brgfreq = 100 MHz
intfreq = 400 MHz
cpmfreq = 200 MHz
busfreq = 100 MHz
ethaddr = 00:00:00:00:00:00
IP addr = 192.168.10.1
baudrate = 9600 bps
=> fatinfo
usage: fatinfo <interface> <dev[:part]>
=> flinfo
Bank # 1: Intel 28F640J3A (64 Mbit, 64 x 128K)
Size: 8 MB in 64 Sectors
Sector Start Addresses:
FF800000 FF820000 FF840000 FF860000 FF880000
FF8A0000 FF8C0000 FF8E0000 FF900000 FF920000
FF940000 FF960000 FF980000 FF9A0000 FF9C0000
FF9E0000 FFA00000 FFA20000 FFA40000 FFA60000
FFA80000 FFAA0000 FFAC0000 FFAE0000 FFB00000
FFB20000 FFB40000 FFB60000 FFB80000 FFBA0000
FFBC0000 FFBE0000 FFC00000 FFC20000 FFC40000
FFC60000 FFC80000 FFCA0000 FFCC0000 FFCE0000
FFD00000 FFD20000 FFD40000 FFD60000 FFD80000
FFDA0000 FFDC0000 FFDE0000 FFE00000 FFE20000
FFE40000 FFE60000 FFE80000 FFEA0000 FFEC0000
FFEE0000 FFF00000 (RO) FFF20000 (RO) FFF40000 (RO) FFF60000 (RO)
FFF80000 FFFA0000 FFFC0000 FFFE0000
## Checking Image at 01000000 ...
Bad Magic Number
=> pci
Scanning PCI devices on bus 0
BusDevFun VendorId DeviceId Device Class Sub-Class
_____________________________________________________________
00.00.00 0x1057 0x18c1 Bridge device 0x00
00.10.00 0x14e4 0xb502 Network controller 0x80
00.11.00 0x14e4 0xb504 Network controller 0x80
one6f
Re: 6850 bad crc error
Post by one6f » 08 Mar 2012 04:51
you have corrupted flash. Damaged components have to be sent in for repair work within the warranty period.
Otherwise you can try diskInit described in attached recovery procedure AT YOUR OWN RISK!
You need here to switch baud rate to 115200 bps in your terminal program and press ENTER.
Dsco
Post by Dsco » 16 Mar 2012 06:44
one 6f
Thkz a lot we will try this and let u kno our status
thkz soooo much u r really great
one more thing i read ur all post itz just great post "u r great"
Dsco
Post by Dsco » 19 Mar 2012 10:50
one6f
Need Hlp Plz
Can U give us software for this version 6.1.3.601.R01
All the Files Plz..
one6f
Post by one6f » 20 Mar 2012 06:55
I can't provide you with AOS releases. Kindly contact your Business Partner or Alcatel-Lucent.
Locked
Return to “Talk to the admins”
