UNABLE TO LOAD STACK MANAGER LIBRARY ABORT!
cliffharewood
Post by cliffharewood » 25 Apr 2011 17:29
I have a switch that won’t boot. I was trying to get it to work in a stack. I used the STACK SET SLOT command but it didn’t work. I used the command again to set it back to position one. Now it won’t boot. I get a message UNABLE TO LOAD STACK MANAGER LIBRARY ABORT!. Can anyone please help?
lmherdvera
Re: UNABLE TO LOAD STACK MANAGER LIBRARY ABORT!
Post by lmherdvera » 21 Dec 2015 08:20
same problem with me, can anyone help us please...
CPU: Motorola MPC8248. Processor #0.
Memory Size: 0x20000000 (512 MB). BSP version 1.2/1.
Portions of code copyrighted by Alcatel-Lucent 1994-2014. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
0x1ffffde0 (tRootTask): cmm_random_init OK
0x1ed773e0 (tWhirlpool): batch_entropy_process called
Target Name: vxTarget
User: target
Attaching network interface lo0... done.
The current date and time is:
Coordinated Universal Time (UTC): MON DEC 21 13:37:44 2015
Local time: MON DEC 21 13:37:44 2015 GMT
Starting dynamic software load from '/flash/certified/'...
unable to load Stack Manager Library - ABORT!
devnull
Post by devnull » 11 Jan 2016 06:54
probably a corrupt or missing image in /flash/certified
Do a x/zmodem recovery (google or search forums)
consider some newer device (6800 is end of everything since a couple of years)
Return to “OmniSwitch 6800”
