We need a map bigger than 2000x2000 pixels
Evox
Post by Evox » 02 Sep 2015 06:05
Hello !
I have a problem,
Actually we have a lot of Network Elements to add per Group folders. (hundreds)
But It seems We can't scroll down indefinitely like others NMS, i searched in the 'Help' and it seems there is a size limit like this
Do you think there is a way to unlock that limit ? :?
Thanks You !
DoobieHowserMD
Re: We need a map bigger than 2000x2000 pixels
Post by DoobieHowserMD » 18 May 2017 13:16
You cannot change the map size at this time. To "fit" more you need to utilize the group function to split the NE's into separate maps.
aviviis
Post by aviviis » 16 Mar 2018 12:09
We have the same problem
What is your email ?
Return to “5620 SAM”
