I've bought this switch recently and I'm having issue logging in the CLI.
Does any one know the default login of this switch? Isn't it "admin" for the username and "switch" for the password?
I've tried "admin" for the username and "password" for the password but still didn't work.
I've tried the reset button too...at this point I am stumped...
Thank you in advance! Any help will be greatly appreciated!
7210 SAS-M login
Re: 7210 SAS-M login
For the main router login prompt the default username/password is admin/admin.
If you interrupt the boot sequence to perform a manual boot for the first time the default password for the boot options file is "password".
yes i've tried admin/admin and i still doesn't work..
Login:
Login:
Login:
Login: admin
Password:
Login:
Login:
Login:
Login: admin
Password:
Login: admin
Password:
Login: admin
Password:
i can stop the boot sequence and use "password" for the password...
Hit a key within 3 seconds to change boot parameters...
Enter password to edit the Boot Options File
Or CTRL-D to exit the prompt
Password:
You must supply some required Boot Options. At any prompt, you can type:
"restart" - restart the query mode.
"reboot" - reboot.
"exit" - boot with with existing values.
"reset" - reset the bof and reboot.
Press ENTER to begin, or 'flash' to enter firmware update...
Login:
Login:
Login:
Login: admin
Password:
Login:
Login:
Login:
Login: admin
Password:
Login: admin
Password:
Login: admin
Password:
Password:
"reboot" - reboot.
Interrupt the boot sequence and change the boot options so that primary-config is set to none. (Check that secondary-config and tertiary-config are also not set).
The system will then boot with a default config and you should be able to use admin/admin
awesome! you're the man! thank you so much. I've only been working with Cisco so this is totally new to me.. anyway, i changed the primary-config to none and admin/admin worked!
