Show MAC address table
bogdand
Post by bogdand » 08 Mar 2016 03:03
Hi guys,
I've been given access to a Looking Glass application and I'm trying to use a command implemented for showing the MAC addresses but it doesn't seem to work
ALU SAS IP: X.X.X.X
7210_# show mac
Error: Invalid parameter.
I was trying to find some documentation regarding the command but I really can't seem to find one. I want to check the syntax and maybe contact our admin for the LG app and settle this.
Could you please help?
BD
paramount
Re: Show MAC address table
Post by paramount » 08 Mar 2016 08:07
This will generally be service based if you're looking for a mac table.
The 7210 follows the same structure as the 7750, so should be:
show service id XXXX fdb detail
XXXX will be the VPLS service ID.
Cheers
bogdand
Post by bogdand » 09 Mar 2016 01:29
paramount wrote:Hi,
Cheers
Thanks mate,
I'll try to get my hands on a 7210 and check it myself and I'll post it back here. Thanks for the information, I'm surprised it's not a command to show all MAC addresses at once, not per VLAN basis.
mivens
Post by mivens » 09 Mar 2016 04:34
That command is indeed the same for the 7210.
It's not all MAC addresses at once - the command is It's per service i.e. per VPLS instance. A MAC learnt on a SAP in one local VPLS instance is not going to be in the FDB table for a second VPLS service.
thecandymancan
Post by thecandymancan » 20 Mar 2016 17:33
show service fdb-mac gives you all VPLS tables in one shot
Check out my new NRS1 study guide here: https://www.snu.training/books.html
SRA #250
CCIE #40869
NRS2 #1268
http://iamjeffvader.com/
Return to “7210 SAS”
