Can I use DWDM lasers[1533.47nm] in 7210 SAS-M
skhaderk
Post by skhaderk » 25 May 2016 14:57
Can I use DWDM lasers[1533.47nm] in 7210 SAS-M, dropping out of SFD44.
mivens
Re: Can I use DWDM lasers[1533.47nm] in 7210 SAS-M
Post by mivens » 27 May 2016 06:54
If you check the Release Notes you will see that the Alcatel part number 3HE02718AT below is listed as supported.
3HE02718AT 1-port 10GBASE-DWDM Small Form-Factor Pluggable (XFP) Optics Module, 1533.47 nm/Channel 55 (100GHz ITU Grid, C-Band), 80 km, LC Connector
Return to “7210 SAS”
