SDP between7705SAR-M and Huawei NE40
shadowmaker
Post by shadowmaker » 16 Sep 2016 09:29
Hello dear people, I am newbie with Alcatel technology and I am trying to establish an sdp between a 7705 SAR-M and a Huawei NE40 and so far I couldn´t.Also Tried to establish it between 7210 SAS-M and a Huawei and also was unsuccessfull.
Just for testing purposes I already established it successfully between a 7705 SAR-M and a 7210 SAS-M.
Is there any interoperability restriction or bug?
The SW versions are this
7705 SAR-M TiMOS-B-7.0.R6
7210 SAS-M TiMOS-B-8.0.R6
Please help me, I am really desperate with this issue.
The successfull config between the ALUs is below.
Thanks in advance for your feedback.
*A:ALU# show router route-table 181.209.0.182
Route Table (Router: Base)
Dest Prefix[Flags] Type Proto Age Pref
Next Hop[Interface Name] Metric
181.209.0.182/32 Remote ISIS(1) 02d23h00m 18
192.168.222.5 2000
No. of Routes: 1
Flags: n = Number of times nexthop is repeated
B = BGP backup route available
L = LFA nexthop available
*A:ALU# show router route-table 181.209.0.175
181.209.0.175/32 Remote ISIS(1) 02d23h05m 18
192.168.222.5 1000
No. of Routes: 1
*A:ALU#
*A:ALU>config>service# info
sdp 2225 create
far-end 181.209.0.175
ldp
keep-alive
shutdown
exit
no shutdown
exit
sdp 2226 create
far-end 181.209.0.182
ldp
keep-alive
shutdown
exit
no shutdown
*A:ALU# show service sdp
Services: Service Destination Points
SdpId AdmMTU OprMTU Far End Adm Opr Del LSP Sig
2225 0 9174 181.209.0.175 Up Down MPLS L TLDP
2226 0 9174 181.209.0.182 Up Up MPLS L TLDP
Number of SDPs : 6
Legend: R = RSVP, L = LDP, B = BGP, M = MPLS-TP, n/a = Not Applicable
*A:ALU#
wruozhou
Re: SDP between7705SAR-M and Huawei NE40
Post by wruozhou » 09 Aug 2018 12:43
Have you resolve your problem? I try to establish a sdp between a sr7750 and a huawei ne40e.And it can not work.
Stoffen
Post by Stoffen » 18 Aug 2018 05:55
Hi.
Please give us output of "show service sdp <id> detail", and other details you may have/provide.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
ronnielvnet
Post by ronnielvnet » 05 Sep 2018 16:08
Also might want to do a packet capture between the known, working pairs and the huawei one and see whats different.
Return to “7705 SAR”
