SNMP Configuration on SR 7750
hamadaltaf
Post by hamadaltaf »
I want to configure snmp on SR 7750.
To start with I will be using snmp to monitor port 1 usage.
Require help to kick start configuration.
jlee003
Post by jlee003 »
configure system
snmp
no shut
packet-size 9216 (or whatever you want)
exit
security
snmp
community "xxxxxx" r version both
community "xxxxx" rwa
community "xxxxxx" rwa
exit
That should get you started, remember your trap groups are built under the conf system log root. If you want to enable persistance you will need to do that through the bof with "bof persist on"
hamadaltaf
Thanks for the reply, jlee003..
jlee003
Post by jlee003 »
no problem, hoped that helped
dsdwn
Re: SNMP Configuration on SR 7750
Post by dsdwn »
is there a quick how-tow for snmp.v3 too ?? (TimOS v. 7.X is running)
I'm a little bit confused 'bout building the passphrase-hashes for the users
thekotaksampah
Post by thekotaksampah »
Dear All,
Please inform me, can I get snmp information using IP bof? I mean the snmp packet transfer to agent over Management Port in SFM, Or I have to add additional configuration in under system configuration context. I've read OS System Configuration guide, but there is no explanation how the snmp packet sent to agent.Using inband (IGP link) or outband (Management Port).
Thanks guys
Technical Blog: ngoprek.achyarnurandi.id
rekeds
Post by rekeds »
dsdwn wrote:is there a quick how-tow for snmp.v3 too ?? (TimOS v. 7.X is running)
I use snmpkey to generate hash.
rekeds
Post by rekeds »
thekotaksampah wrote:Dear All,
Thanks guys
different route tables.
thekotaksampah
Thanks guys
What does it mean with different route table?
hhemachundra
Post by hhemachundra »
Was trying to discover 7750 nodes using Solarwinds and SNMPV3.
This post has helped, where it was suggested to use snmp hash generator.
Have used online generator for a keyword and on solarwinds rather than providing password, entered key and able to discover node.
Thank you for your help
Return to “7750 SR”
