I haven't tried this myself, but the vRR-Install guide from ALU states the following;mjohans wrote:Has anyone got MC-Lag to work using the Virtual SROS? I can get OSPF, MPLS to work and the MC-Lag is up, but the lag is standby in both machines. If I turn off the port between them, both go in active mode.
I've tried gns3 v1.2.3, as well as the virtual manager program using the xml files to build the links between them, no difference.
Limitation
HA is not supported on the vRR or the integrated vSIM
MTU is capped to 8936
12.0 is currently limited to 4G memory
The following VM parameters can not be changed dynamically on a running vRR VM
o Change the number of vCPUs
o Change the CPU pinning configuration
o Change the amount of memory
o Add or remove a disk
o Add or remove an interface
Since MC-Lag is a HA feature, it might not be supported.
This is written for the 12.0 release. Releasenotes for 13.0 states no change for the vSIM environment.
