Multicast forwarding in RVPLS
Krabntas
Post by Krabntas »
Hi All,
a complicated problem :)
I have a problem with Multicast recieving in VPLS attached to IES interface, the traffic is unstable, i also notice when zapping between channels and going back to the same channel (fast re-join 2 seconds after the last leave) the udp stream stops while states on R1 below that its active! , although no packets are sent out the Interface.
I cant find anything that fix the unstability issue , i think there is a problem in backplane forwarding between IES interface and SAPs inside the VPLS
The topology is as follows:
Reciever 1 --- --- R2 7750SR------------
R1 7750SR===== =====Source
Reciever 2 --- --- R3 7750SR -------------
Some facts about the topology
1- Recievers are working in IGMPv3
2-recievers are configured with no specific sources
3- R1,R2,R3 are confiugred with PIM SSM
4-IES interface is configured as IGMP querier
5- VPLS service is configured with IGMP-snooping send-queries
6-PIM neighbor relation with R2 R3 have no problem
7-static ssm translation is configured on all routers (no RP)
What i did tried to modify with no luck
1-Igmp query intervals
2-Last member query interval
3- tried looking into the vpls fdp igmp and it states that the channel 232.0.1.150 is fwded to the user
4-show ip pim group 232.0.1.150 details is showing that traffic is recieved via R1 PIM interface and sent to IES_Video interface
5- show service id 23212310 igmp-snooping port-db sap 6/1/1:100.* detail shows that MC group 232.0.1.150 is active to SAP.
Below are some ommitted parts to have a full view
-------R1-----
vpls 23212310 customer 1 create
split-horizon-group "Video-Service" create
description "Video-Service"
stp
shutdown
exit
igmp-snooping
no shutdown
exit
service-name "IES_23212310"
allow-ip-int-binding
sap 6/1/1:100.* split-horizon-group "Video-Service" create
description "Subscriber1"
igmp-snooping
send-queries
exit
exit
service
ies 23221231 customer 1 create
description "BTV L3 GW"
interface "IES_Video" create
description "IES Video to VPLS23212310 "
unnumbered
ip-mtu 1500
vpls "IES_23212310"
exit
exit
*A:R1>config>router>igmp# info
exit
no shutdown
A:R1# show router pim group 232.0.1.150 detail
PIM Source Group ipv4
Group Address : 232.0.1.150
Source Address : x.x.x.x
RP Address : 0
Advt Router : x.x.x.2
Flags : Type : (S,G)
MRIB Next Hop : x.x.x.x
MRIB Src Flags : remote
Keepalive Timer : Not Running
Up Time : 16d 19:25:45 Resolved By : rtable-u
Up JP State : Joined Up JP Expiry : 0d 00:00:28
Up JP Rpt : Not Joined StarG Up JP Rpt Override : 0d 00:00:00
Register State : No Info
Reg From Anycast RP: No
Rpf Neighbor : x.x.x.x
Incoming Intf : to_R2
Outgoing Intf List : IES_Video
Curr Fwding Rate : 7723.8 kbps
Forwarded Packets : 1034543721 Discarded Packets : 0
Forwarded Octets : 1402841285676 RPF Mismatches : 0
Spt threshold : 0 kbps ECMP opt threshold : 7
Admin bandwidth : 1 kbps
Groups : 1
k4k4k
Re: Multicast forwarding in RVPLS
Post by k4k4k »
Hi Have you found a solution to this?
i have the same isue,, but it is OK now,,
from R1 & R3,, can you reached the source's IP address?
have you configured ssm under pim & igmp, example :
igmp
ssm-translate
grp-range 232.0.5.1 232.0.5.5
source 200.1.8.1
exit
exit
pim
ssm-groups
group-range 232.0.5.0/24
exit
Krabntas
Post by Krabntas »
Its shown to be a bug in SW release R12 if this would help you...
cheers :)
mivens
Post by mivens »
Fixed in 12.0R13 and 13.0R5.
shadowmaker
Post by shadowmaker »
Hello, could You please give me the details from this bug?
Thanks a lot for your help.
Best Regards
mivens
Post by mivens »
From the Release Notes:
When using “ssm-translate” in a Routed-VPLS service, if a (*,G) join had been received in the VPLS and translated to an (S,G) to be sent to the routed side of the service, the related multicast stream would have been forwarded correctly; however, if the same (*,G) had been later received on a SAP or mesh-/spoke-SDP on a different forwarding complex than the initial join, then the multicast stream would not have flowed towards that new complex. This issue has been resolved. [211398-MA]
Return to “7750 SR”
