Is there an MIB for the 7750?
Re: Is there an MIB for the 7750?
There are lots of MIBs for the 7750.
There is a MIBs folder in the zip file in which the SR OS software is distributed.
You may also find older versions on the web.
For example, the MIBs with filenames starting with "TIMETRA-" here:
https://github.com/pgmillon/observium/t ... r/mibs/aos
(Timetra is the company that Alcaltel bought that originally made the 7750).
This was really great info !!. Thanks a lot !mivens wrote: ↑14 Mar 2017 04:34 There are lots of MIBs for the 7750.
