Hi, trying to get a few 7750 devuices running in GNS3, i think im nearly there but when hitting the console connection, im getting the message
Alcatel7750timos12.0R6-1" requires 2048MB of RAM to run but there is only 1747MB - 12.7% of RAM left on "gns3vm
Any ideas how to resolve? Is it something on the Virtual Machine, are there any changes i can make to any settings to get it to run? thanks
Timos image issues in GNS3
- thekotaksampah
Re: Timos image issues in GNS3
I am not familiar with GNS3. But if you wan to explore more. It's better use EVE-NG visit http://www.eve-ng.net/. it's linux based. So you can change the metadata to make suit with your system.
Technical Blog: ngoprek.achyarnurandi.id
Hi.
Just ran into this myself, and I think you need to alter the amount of memory your GNS3 VM has to play with.
Go to Preferences, GNS3 VM, and increase the RAM size for your VM.
I did however get to boot the SROS with only 2048 MB RAM for my GNS3 VM, but I suspect this will not be stable if multiple SR's are beeing booted.
GNS3 reported error:
"SR-1" requires 2048MB of RAM to run but there is only 1733MB - 13.3% of RAM left on "gns3vm"
But its running..
Running in a KVM/QEMU virtual machine
Enabled core count: 1
sysSmpDisabled WARNING: #######################################################
sysSmpDisabled WARNING: Simulating a multicore board on a single core simulator
sysSmpDisabled WARNING: Some features will behave differently
sysSmpDisabled WARNING: * SMP is not being simulated
sysSmpDisabled WARNING: * not running 64-bit architecture
Total Memory: 2047MB Chassis Type: 0x2 Core Freq: 2708.625 MHz
TiMOS-B-13.0.R7 both/i386 ALCATEL SR 7750 Copyright (c) 2000-2016 Alcatel-Lucent.
All rights reserved. All use subject to applicable license agreements.
Built on Mon Jan 11 18:00:01 PST 2016 by builder in /rel13.0/b1/R7/panos/main
___ ___ ___ ___
/\ \ /\__\ /\ \ /\ \
\:\ \ ___ /::| | /::\ \ /::\ \
\:\ \ /\__\ /:|:| | /:/\:\ \ /:/\:\ \
/::\ \ _\/__/ /:/|:|__|__ /:/ \:\ \ _\:\~\:\ \
/:/\:\__\ /\__\ /:/ |::::\__\ /:/__/ \:\__\ /\ \:\ \:\__\
/:/ \/__/ /:/ / \/__/~~/:/ / \:\ \ /:/ / \:\ \:\ \/__/
/:/ / /:/ / /:/ / \:\ /:/ / \:\ \:\__\
\/__/ \/__/ /:/ / \:\/:/ / \:\/:/ /
\/__/ \/__/ \/__/
Running 32 bit architecture
Initializing VMM
Virtual address sharing is disabled
emGetLink: unit 0 is not VALID
Time from clock is FRI OCT 13 12:50:26 2017 UTC
Initial DNS resolving preference is ipv4-only
Attempting to exec primary configuration file:
'cf3:\config.cfg' ...
Executed 0 lines in 0.0 seconds from file cf3:\config.cfg
Login: admin
Password:
This simulation software is the property of Alcatel. It may not
be sold, leased, loaned or licensed to any non-Alcatel entity.
A:vRR# show version
A:vRR#
But its running..
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
Christoffer
Nokia SRA #265
[/flash]
if you want to run the image of the nokia router in gns3. You must run it using GNS3 VM (installed on virtualbox or vmware) and set the appropriate amount of RAM (for one router = 2048 MB). Then you have to enable kvm in the image settings (already in the program itself).
The best way of running Nokia routers in GNS3 is to install GNS3 on a Linux server/PC and not mess around with nested virtualisation.
