AS-Override in MPLS L3VPN can't ping
plawansai
Post by plawansai »
My Topology:
PE1 vrf A - PE2 with as-override - PE1 vrf B - PE3 vrf B - CE destination
I see the route can install in the routing table but I can't ping, how should I do?
Thank you very much.
ปลาวาฬทราย
paramount
Re: AS-Override in MPLS L3VPN can't ping
Post by paramount »
Assume you are trying to ping a destination learnt via the BGP peering. Are you pinging from a source address that is known about at the destination?
If so, can you share some output here please, ie show router xxx route-table, show router xxx interface, ping router xxx source yyyy
Paramount
plawansai
Post by plawansai »
PE3# ping router 31010351 10.12.75.254
5 packets transmitted, 5 packets received, 0.00% packet loss
PE2# pin vrf fK7 10.12.75.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 45/476/1163 ms
PE1# show router 31010077 route-table 10.12.75.254
Dest Prefix[Flags]                            Type    Proto     Age        Pref
      Next Hop[Interface Name]                                    Metric
10.12.72.0/22                                 Remote  BGP       00h05m59s  170
       10.202.124.86                                                0
PE1# show router 31010077 interface
Interface-Name                   Adm         Opr(v4/v6)  Mode    Port/SapId
   IP-Address                                                    PfxState
Intf_PCW.2092            Up          Up/Down     VPRN    1/1/3:2092
   10.202.124.85/30                                              n/a
PE1# ping router 31010077 10.12.75.254 source 10.202.124.85
5 packets transmitted, 0 packets received, 100% packet loss
ปลาวาฬทราย
paramount
Post by paramount »
But at the far end, ie at the device with 10.12.75.254, does it have a valid route back to 10.202.124.85?
Can you try a traceroute and see how far it gets also.
Cheers
Paramount
plawansai
Post by plawansai »
CE# sho ip rou
S* 0.0.0.0/0 [1/0] via 10.202.116.49
CE# tra 10.202.124.85
Type escape sequence to abort.
Tracing the route to 10.202.124.85
VRF info: (vrf in name/id, vrf out name/id)
1 10.202.116.49 !N !N !N
ปลาวาฬทราย
Return to “7750 SR”
