Could other vendors see the Nokia port?
plawansai
Post by plawansai »
<Huawei>dis lld nei bri | inc Nokia
Info: It will take a long time if the content you search is too much or the string you input is too long, you can press CTRL_C to break.
Local Intf Neighbor Dev Neighbor Intf Exptime (sec)
GigabitEthernet3/0/0 Nokia1_Lab 136478720 113
GigabitEthernet3/0/7 Nokia1_Lab 136445952 112
Thank you very much.
ปลาวาฬทราย
mivens
Re: Could other vendors see the Nokia port?
Post by mivens »
It's not clear what your question is. Are you asking how to get the PortName rather than IfIndex in the output?
If so, you need the command
/configure port <port-id> ethernet lldp dest-mac nearest-bridge port-id-subtype tx-if-name
plawansai
Post by plawansai »
Great!
Does 7210 support this command?
And could it also show lldp detail :?:
A:Nokia# show system lldp neighbor | match Hua
4/1/4 NB F8:xx:EF:C2:A8:4C 67 GigabitEtherne* Huawei-1
ปลาวาฬทราย
mivens
Post by mivens »
Support on the 7210 was introduced in SR OS 9.0R1.
Bear in mind that the ifIndex value is needed by some versions of 5620 SAM to build a layer-2 topology map using LLDP.
To see more detail:
*A:7750# show port 4/1/4 ethernet lldp remote-info
Link Layer Discovery Protocol (LLDP) Port Information
Port 4/1/4 Bridge nearest-bridge Remote Peer Information
Remote Peer Index 2 at timestamp 05/10/2018 02:56:18:
Supported Caps        : bridge router
Enabled Caps          : bridge router
Chassis Id Subtype    : 4 (macAddress)
PortId Subtype        : 5 (interfaceName)
Port Id               : 47:69:67:61:62:69:74:45:74:68:65:72:6E:65:74:30:2F:33:
                        2F:30
                        "GigabitEthernet0/3/0"
Port Description      : to-7750-4-1-4
System Name           : switch.lab
System Description    : Huawei Versatile Routing Platform Software
                        VRP (R) software, Version 8.100 (CX600
                        V800R007C10SPC100)
                        Copyright (C) 2012-2015 Huawei Technologies Co., Ltd.
                        HUAWEI CX600-M2F
Return to “7750 SR”
