Could Nokia sniff LLDP packet?
plawansai
Post by plawansai »
Could Nokia sniff LLDP packet :?:
Thank you very much.
ปลาวาฬทราย
mivens
Re: Could Nokia sniff LLDP packet?
Post by mivens »
Have a look at the section "Port MIrroring" in the 7750 SR OS OAM and Diagnostics Guide.
plawansai
Post by plawansai »
Could you please narrow down to the commands like this :?:
configure filter log 140 create destination memory 4000
configure filter ip-filter 40 create entry 10 create match protocol ip
back
log 140
action forward
back
entry 20 create match protocol icmp
back
log 140
action forward
ปลาวาฬทราย
mivens
Post by mivens »
Are you asking how you can match an LLDP frame?
It's not an IP packet so you can't explicitly match it in an IP filter.
You could try a mac-filter, something like:
          mac-filter "100"
              entry 10 create
                  match
                      etype "0x88cc"
                  exit
                  action
                     forward
                 exit
             exit
         exit
plawansai
Post by plawansai »
Great!
But It says:
>config>filter>mac-filter>entry# match etype "0x88cc"
MINOR: FILTER #1521 Invalid frame type - E-type cannot be configured/changed.
How should I do :?:
ปลาวาฬทราย
mivens
Post by mivens »
Sorry, I forgot the frame-type is mandatory. Try this instead:
configure filter mac-filter "100" create
  entry 10 create
    match frame-type ethernet_II  etype "0x88cc"
    action  forward
plawansai
Post by plawansai »
How to apply to the network port :?:
ปลาวาฬทราย
mivens
Post by mivens »
You need to first define a destination for the mirrored traffic then with a debug command, start the mirroring. The simplest is to send the mirrored traffic out of another local port.
For example, to mirror the ingress traffic matching mac-filter 100 entry 10 on source port is 1/1/1 to destination port 2/2/2:
 configure
     mirror
         mirror-dest "1" create
             sap "2/2/2" create
             exit
            no shutdown
         exit
     exit
 exit
debug
    mirror-source 1
        port 1/1/1 ingress
        no shutdown
    exit
exit
plawansai
Post by plawansai »
Could it destination to the log or storage :?: Which I can upload over the VPN to my laptop.
ปลาวาฬทราย
mivens
Post by mivens »
It's not a debug command. I do not believe there is an lldp debug command available.
This is copying the raw packets and sending therm out of another port on the 7750.
You would need to connect a laptop running Wireshark (or another packet capture application) to the destination port.
It is also possible to send the mirrored packets over the network to a remote 7750, but this is obviously a bit more complicated to set up.
Return to “7750 SR”
