Need help to enable Netconf
snsuryadipti
Post by snsuryadipti »
I am trying to do netconf from one linux machine to the SR12 device (7750). But not able to connect. I believe 'Operational State' attribute value is 'down'. Please see below.
***SR12-10**# show system netconf
NETCONF Server
Administrative State : Enabled
Operational State : Down
How can we make the Op state Up?
Only these options are showing..
LAB-SR12-102>config>system>netconf# info
no shutdown
Please help!
-Surya
dudepro
Re: Need help to enable Netconf
Post by dudepro »
What version?
Are you using the MD-CLI? What is happening on the Linux side?
lo0
Post by lo0 »
NETCONF will appear oper-down until you establish an active session. Port Mirroring behaves the same way.
Return to “7750 SR”
