IP Desktop Softphone download
esotronic
Post by esotronic » 27 Nov 2014 08:39
Greetings,
I'm allready running a few ip touch phones and they work really well. Now I just ordered some Jabra Headset and want to figure out
of what the hard and software is able to do.
Where can I download the newest mac and windows version of the IP Desktop Softphone software?
Thanks for your help.
Rolf
Re: IP Desktop Softphone download
Post by cavagnaro » 27 Nov 2014 09:46
From Alcatel Business Partner. You need a login and password and be, of course, a partner. If you are not ask the software to your Alcatel provider
esotronic
Post by esotronic » 30 Jul 2017 11:44
Thank you for the feedback. I will give it a try.
Return to “Ip Desktop Softphone”
