TFTP connection rejected Port 69 Unreachable
Daywalker01
Post by Daywalker01 »
I am trying to connect to my OXE wia IP Desktop Softphone 11.0.30 but after the weekend it stopped working.
The client is just displaying "CONNECTION LOST"
But all the Physical Phones are working (different subnet and VLAN thought)
I traced the communication with Wireshark but the only communication I got was the Following:
(10.1.1.2 is the OXE)
99	6.193379000	10.17.195.13	10.1.1.2	TFTP	92	Read Request, File: lanpbx.cfg, Transfer type: octet, blksize\000=1428\000, timeout\000=5\000, tsize\000=0\000
100	6.193430000	10.17.195.13	10.1.1.2	TFTP	92	Read Request, File: lanpbx.cfg, Transfer type: octet, blksize\000=1428\000, timeout\000=5\000, tsize\000=0\000
101	6.193776000	10.1.1.2	10.17.195.13	ICMP	120	Destination unreachable (Port unreachable)
102	6.193778000	10.1.1.2	10.17.195.13	ICMP	120	Destination unreachable (Port unreachable)
145	11.193903000	10.17.195.13	10.1.1.2	TFTP	92	Read Request, File: lanpbx.cfg, Transfer type: octet, blksize\000=1428\000, timeout\000=5\000, tsize\000=0\000
146	11.193944000	10.17.195.13	10.1.1.2	TFTP	92	Read Request, File: lanpbx.cfg, Transfer type: octet, blksize\000=1428\000, timeout\000=5\000, tsize\000=0\000
147	11.194593000	10.1.1.2	10.17.195.13	ICMP	120	Destination unreachable (Port unreachable)
148	11.194595000	10.1.1.2	10.17.195.13	ICMP	120	Destination unreachable (Port unreachable)
Configured as TFTP Servers would be 10.1.1.2 and 10.1.1.3 as backup but communication is just issued to 10.1.1.2
I was looking on the OXE and the Port is definetly open
> netstat -tulpen | grep :69
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
udp        0      0 0.0.0.0:69              0.0.0.0:*                           0          10684      -
What am I missing here?
Thank you in advance
[ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "Lucky boy";
Split
Re: TFTP connection rejected Port 69 Unreachable
Post by Split »
Hi daywalker did you find a solution? I have the same problem and my tcpdump show this message to. If i use the android client it works ....strange
ACSE OmniPCX Enterprise Business R9/10/11
ACSE ICS 8400 R6
ACSE OpenTouch R1/R2
Return to “Ip Desktop Softphone”
