Import TAXAxxxx.DAT files into 4760 DB
sitig
Post by sitig »
Hi All
Is there a way we can import the Accounting files from OXE into the 4760 DB??
I have been reading a few posts and someone mentioned that we copy all these files into the collector folder and then import. Is there a tool to run to extract the tickets from these files and import them into the 4760??
I've got the files but am struggling with it. I'm running R5.2.
Any advice is appreciated.
Many Thanks.
Every adversity has within it a seed of an equivalent or greater benefit....
alexeik
Re: Import TAXAxxxx.DAT files into 4760 DB
Post by alexeik »
Why not with sync between the 4760 and oxe?
sitig
Post by sitig »
Hi Alexelk
I've got files from 2015. I was syncing them one by one, meaning, loading the OXE acc backups, and then syncing the 4760. Firstly, it was a long process, and secondly some of the ticket files were rejected. So I could not get accurate reports.
I was looking for an easy way....haha...
Thanks for responding anyway.
Cheers.
alexeik
Post by alexeik »
then you get the easy way :)
download the DAT files to the folder <OV4760 dir>/data/loader/networknumber=X and stop the NMC Loader service. It will start again alone and load the DAT files
sitig
Post by sitig »
Thanks alexelk, I'll try that..
Return to “4760”
