Dear Presales,
I'm looking for a SMS solution to connect to an OXE.
SMS must be sent to the screens of the operator consoles (4059EE IP + 8039 premium deskphone) and they must be able to send SMS from their screen. Incoming SMS must be viewable on all the operator consoles simultaneously. There are 5 operator consoles.
Anyone has a good suggestion? (Mobicall is too expensive!)
SMS server (or app)
- frank
Re: SMS server (or app)
Check out with the AAPP. I will send you a private message with a contact.
If not, check out with systel or source tech. If your solution does not exist, they can develop it.
I have the same problem
- cavagnaro
Then you have exactly same answer
Who can develop it? To whom should I write?
Check out NewVoice Mobicall, try Google.
Regards LT
Regards LT
- frank
michael74
System or SourceTech.
They have forums available on this board.
System is actually a sponsor. See the banner at the top of the board.
