Conference for more then 5 parties with OXO
Ask your questions, regarding data or voice!
menashe
Post by menashe » 10 Jan 2016 23:58
Is there a way of making a conference with a single telephone for more then 5 parties and for more then 6 parties in a room.
It can be also with applience that will be connected to OXO or with a SIP phone that allows more then 5 parties.
Thanks,
Menashe
L_lefante
Re: Conference for more then 5 parties with OXO
Post by L_lefante » 25 Jan 2016 14:30
You need to configure Meet me conference for that. Specific license is also needed.
Maulwurf
Post by Maulwurf » 26 Jan 2016 02:39
No way. You are on oxo. You need an external Server or Service.
L_lefante
Post by L_lefante » 26 Jan 2016 09:03
Maulwurf wrote:No way. You are on oxo. You need an external Server or Service.
That is not correct. In OXO you can have Meet Me Conference feature wich allows you to join up to 6 parties to a conference bridge, and there is no need to have an external server. Please check OXO documentation for more details.
Maulwurf
Post by Maulwurf » 26 Jan 2016 12:54
Yes. I thought the question is more than 6.
menashe
Post by menashe » 27 Jan 2016 17:27
Which external server can be connected to OXO to allow more theb 6 parties in a conference room and more then 5 parties dialing from a phone.
There are SIP phone that allow 5 parties and more but they are not accepted by Alcatel, although they are working fine (SNOM 821 for example).
Do you know of other phones that are accepted by Alcatel and have more then 5 party conference.
Thanks,
Menashe
Maulwurf
Post by Maulwurf » 28 Jan 2016 02:54
We use Xphone connect Server with oxo via sip Trunk. With Software Client you can start conferncing. Quick and easy conferncing is possible with many parties.
menashe
Post by menashe » 30 Jan 2016 07:36
Thanks very much, it looks like the solution
Post by tot3nkopf » 02 Feb 2016 11:45
Use an Asterisk box for conferencing.
PlanoPCX
Post by PlanoPCX » 09 Feb 2016 16:46
How about the Alcatel-Lucent 4135IP, it is supported by OxO and has support for multiparty within it.
As per the datasheet " Four simultaneous connections can be linked to create a five-way call"
http://enterprise.alcatel-lucent.com/as ... asheet.pdf
Return to “Pre-Sales”
