OXE Compatability with OmniVista 4760
Ask your questions, regarding data or voice!
umar14
Post by umar14 » 07 Apr 2016 12:37
I have an OXE R11.0 and OmniVista 4760 R5.2. My License File for OmniVista says Configuration Module = 0. I asked for a GUI Configuration module for OXE but my Supplier says that OXE supports only CLI for Configuration. My question is that can I have the Configuration Module in OmniVista 4760 to perform configurations in mgr using GUI or not?? My Supplier told me that even if I had the license for configuration module in OmniVista, it would not work with OXE R11.0 version, It works with older versions like R6.0 R7.0 etc..
Is my supplier right or not?
Any help would be really appreciated.
Thanks in advance
tgn
Re: OXE Compatability with OmniVista 4760
Post by tgn » 07 Apr 2016 15:24
4760 is deprecated and replaced by 8770.
it may be that it can connect to an oxe r11.0, but no one will guarantee the function.
4760 license can be migrated to 8770 license.
regards...
--- back to basics... focus your eyes on the essential things... ---
alexeik
Post by alexeik » 08 Apr 2016 02:23
This is not exactly right.
You are forced to change to 8770 only with release 11.2. Until then you can use 4760 perfectly, and you can buy new licenses for 4760.
This is a license file for config and accounting for 170 User.
; Omnivista 4760 License File
[4760]
Version = 13
Signature = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
4760OfferNumber = xxxxxxxxxxxxxxxxxxxxx
[ALIZE]
Management = 1
[A4400]
Management = 1
4760Handle = xxxxxxxxxxxxxxxxxxxx
; list of applications and capacities
[Modules]
Configuration = 170
Alarms = 0
Topology = 0
Accounting = 170
AccountingMonitoring = 0
PastTimePerformance = 0
VoipPerformance = 0
Directory = 0
NmcClients = 1
Subscribers = 170
Security = 0
TicketCollector = 0
Audit = 0
SipManager = 0
tgn
Post by tgn » 08 Apr 2016 02:52
ah... ok... maybe i'm wrong...
regards...
Post by cavagnaro » 08 Apr 2016 11:10
I also had tgn idea...all R11 to be 8770
Do you have some Alcatel doc on that?
umar14
Post by umar14 » 08 Apr 2016 13:27
So I just need to purchase License for Configuration Module and my OmniVista 4760 will work with OXE R11.0 ??
tgn
Post by tgn » 08 Apr 2016 15:40
found it...
tc0418en-ed16 -> Version 5.2.03.00.c is working up to OXE R11.0.1
but
releasepolicyinfo ENT_MLE_016248-ed37d -> 4760 5.2.x is End of Addon and Phaseout -> April 2016
so i'll prefer not to use 4760 anymore, because no one will fix possible bugs.
regards...
Re: RE: Re: OXE Compatability with OmniVista 4760
Post by cavagnaro » 09 Apr 2016 10:09
umar14 wrote:So I just need to purchase License for Configuration Module and my OmniVista 4760 will work with OXE R11.0 ??
No, you can't say I will buy this or the other. Have to be provided by your supplier.
As it is going as phase out would be wiser and less expensive to get migration. If not later if you want to add some license you will have to buy again probably...
tgn wrote:found it...
but
regards...
Thanks tgn :)
acanais50
Post by acanais50 » 17 May 2017 08:03
tgn wrote:
07 Apr 2016 15:24
it may be that it can connect to an oxe r11.0 mutuelles TNS, but no one will guarantee the function.
regards...
Thank you very much for this information. We will try and tell you how it works. Well, if it works.
Return to “Pre-Sales”
