Attendant Serial Calling
Ask your questions, regarding data or voice!
Redafakher
Post by Redafakher »
This feature enables the attendant to transfer trunk calls that return to the same attendant position after the called party hangs up .
does this feature available in OXE OR OXO which release ?
thanks
Re: Attendant Serial Calling
I think you ask about next feature (exist in OXE):
Chained Call
Routing with chained release.
Routing with chained release allows the attendant to transfer an external call to an internal set. The external party is rerouted to the attendant set as soon as the internal user has on-hooked.
Return to “Pre-Sales”
