Correlator Data checksum
Galileon
Post by Galileon »
I am trying to send a collelator data for CSTA via ISDN user-user message.
User-User i encoded properly:
| IE:[18] CHANNEL (l=3) a9 83 9c -> T2 : B channel 28 exclusive
| IE:[1e] PROGRESS_ID (l=2) 80 83
| IE:[6c] CALLING_NUMBER (l=9) -> 01 a1 Num : 8883002
| IE:[7d] HLC (l=2) 91 81
| IE:[7e] USER_USER (l=37) 00 45 : CSTA
| [80] Correlator Data (l=32):
| 5a c0 30 31 32 33 34 35 36 37 38 39 30 31 32 33 : 'Z.01234567890123'
| 34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39 : '4567890123456789'
But i have a big problem with checksum at the end. I dont know how to calculate it :(
Have tried with crc8 and similar methods but the result always is not as al required.
Proper checksum for data above is 0x7e
Do You have some idea?
Best Regards
Galileon
krzysioD
Post by krzysioD »
Networked Correlator Data, ALU's document ref no 3BA 19598 CKAA :rolleyes:
need some more than BPWS to access this, so I don't post it here.
vsc77420
Re: Correlator Data checksum
Post by vsc77420 »
Hello krzysioD ,
I have an issue when moving from ISDN to businesstalkip , I need to transmit correlator data and maybe your document can answer me.
Could you please send it to me by mail vsc77420@gmail.com?
thanks
Return to “CSTA”
