OmniPCX Offiice - get list of valid extentsions.
alinawaz
Post by alinawaz » 04 Mar 2015 03:37
Hi Everybody,
I am using CSTA API 5 . I am trying to get list of all valid extensions from the OmniPCX Office PBX but can't find any help about it in developer guide.pls can anyone tell me which function should i use to get list of valid extensions from PBX.
Re: OmniPCX Offiice - get list of valid extentsions.
Post by cavagnaro » 04 Mar 2015 11:48
CSTA is a control and information protocol. For doing what you need I guess you must go via XML API
alinawaz
Post by alinawaz » 09 Mar 2015 05:22
thanks, i appreciate your concern.
can you please refer XML API documentation and samples, because i have never heard about the XML API for OmniPCX Office PBX.
i am looking forward for your feedback.
Post by cavagnaro » 09 Mar 2015 08:43
Office...i missed that
XML API is not available for Office
Still CSTA will not help you neither nor TAPI
Don't know which other interfaces does OXO provides, hope some OXO expert can answer that
alinawaz
Post by alinawaz » 22 Apr 2015 05:04
we don't have direct access to an Expert person related to OmniPCX Office.
can you give me some advice on which forum or site I should ask this Question.
Post by tot3nkopf » 22 Apr 2015 05:24
Try here:
https://applicationpartner.alcatel-luce ... /Home.jspx
You will find the list with all available APIs for all ALE products and the procedure to register and get them.
Return to “CSTA”
