Olá, preciso responder um questionário sobre a Alcatel 8770, alguém poderia me ajudar com as respostas ???
The OmniVista 8770 is all modular. Among its modules which are default, basic?
Unified User Management and Device Management; Configuration of a system or the global network; Audit; Topology
Security; Audit; Topology
Maintenance; Security; Configuration of a system or the global network; Alarms
Security; Alarms; Audit; Topology
Maintenance; Security; Topology ; Configuration of a system or the global network; Alarms
*4. How many users on a single server can be managed?
10.000
13.000
30.000
50.000
100.000
*5. How many users and nodes can be managed with distributed architecture?
100.000
120.000
123.000
150.000
>150.000
*6. How the omnivista becomes a proactive tool?
As soon as an alarm occurs, OmniVista 8770 receive an e-mail, and immediately sends another e-mail to notify the appropriate person, for proactive management.
As soon as an alarm occurs, OmniVista 8770 receive an e-mail, and immediately acts on the problem, notifying the person in charge for proactive management.
As soon as new information is generated, OmniVista 8770 sends an e-mail, an alarm or launches an application to notify the appropriate person, for proactive management.
As soon as new information is generated, OmniVista 8770 sends an e-mail, an alarm or launches an application to notify the appropriate person, and immediately acts on the problem for proactive management.
*7. What formats can be generated accounting and performance reports?
Excel, .PDF, HTML, Text files and PPT
Excel, .PDF, Text files and PPT
Excel, HTML, Text files and PPT
Excel, .PDF, HTML and Text files
Excel, .PDF, and Text files
*8. The OmniVista 8770 configuration provides local or remote management of a single
Alcatel-Lucent OmniPCX and OpenTouch or network (i.e., multiple nodes of the
OmniPCX Enterprise and OpenTouch).
The network manager can quickly and easily edit, create or delete any network
object in the managed network. Is this true?
Yes
No
*9. A configuration tree is very different that the mgr because:
The items listed are other
The order of the items is not the same
Changes are offline
Unable to access all items in the PBX
There is no difference
*10. What is the Java version which should be available on the server for the installation of OmniVista?
6
7
8
Any version may be available
The version is determined at the time of installation of the OmniVista
*11. About the software compatibility is possible to affirm that…
The other applications on the machine must not use an OmniVista 8770 serverdedicated port. Do not install IIS livered with Windows server. Do not install the Active Directory delivered with Windows server. Do not install applications that
update system libraries (dll files). The DAP Manager (for IP-DECT system) can be installed on the same computer as the OmniVista 8770 server.
The other applications on the machine must not use an OmniVista 8770 serverdedicated port. Do install IIS delivered with Windows server. Do not install the Active Directory delivered with Windows server. Do not install applications that update system libraries (dll files). The DAP Manager (for IP-DECT system) do not can be installed on the same computer as the OmniVista 8770 server.
The other applications on the machine can use an OmniVista 8770 server-dedicated port. Do install IIS delivered with Windows server. Do not install the Active Directory delivered with Windows server. Do not install applications that update system libraries (dll files). The DAP Manager (for IP-DECT system) do not can be installed on the same computer as the OmniVista 8770 server.
The other applications on the machine can use an OmniVista 8770 server-dedicated port. Do not install IIS delivered with Windows server. Do not install the Active Directory delivered with Windows server. Allowed to install applications that update system libraries (dll files). The DAP Manager (for IP-DECT system) can be installed on the same computer as the OmniVista 8770 server.
The other applications on the machine must not use an OmniVista 8770 serverdedicated port. Do not install IIS delivered with Windows server. Do not install the Active Directory delivered with Windows server. Allowed to install applications that update system libraries (dll files). The DAP Manager (for IP-DECT system) do not can be installed on the same computer as the OmniVista 8770 server.
*12. When the OmniVista installation as must be the firewall and antivirus tools?
Firewall stopped and antivirus started
Firewall stopped and antivirus stopped
Firewall stopped and antivirus uninstalled
Firewall started and antivirus started
*13. What makes the OmniVista run for only 30 days?
OXE license valid for 30 days
OXE which has the license of registered OmniVista does not synchronize with OmniVista
The OmniVista must be validated every 30 days
The license of the modules has been validated only for 30 days
OminiVista never run for only 30 days
*14. If you have not configured your mail server during installation, do you can do it later? And which the mail sender default?
Yes. customername@servername.dnssuffix
No. customername@servername.dnssuffix
No. omnivista@servername.dnssuffix
Yes. omnivista@servername.dnssuffix
*15. To change the computer name or the Windows DNS suffix is necessary…
Uninstall the OmniVista 8770 server
Nothing. It is transparent.
Stop the windows services
change the server license
Stop the windows services and change the server license
*16. The applications available and the maximum number of users allowed by application depend on the license installed on the server. What is the path where the new license should be placed?
8770\nmc
8770\etc
8770_ARC\etc\ license
8770_ARC\ nmc\ license
8770\bin\license
*17. Which is the command on the OXE used for to discover the Network Number, Node Number and Subnetwork used in the configuration to connection with PABX?
spadmin
lanpbxbuild
siteid
sitied
spadmin and sitied
*18. In case of spatial redundancy (OmniPCX Enterprise only), you must enter both the main IP addresses corresponding to the CPUs. How to do?
copy and paste after to access OXE through the mgr
right click on the field Add value to enter the second IP address.
left click on the field Add value to enter the second IP address.
All answers are true
*19. Which is command to discover the CPU IP address through the mgr?
>netadmin -n and to select option 3 then 1. View
>netadmin -m and to select option 4 then 1. View
>netadmin -m and to select option 3 then 1. View
>netadmin -n and to select option 4 then 1. View
>siteid and to select option 3 then 1. View
*20. OMC is the PC application used to configure OmniPCX Office parameters. Which is procedure to know the CPU IP Address?
Comm > Connect. Then Navigate to OMC: Hardware and Limits > LAN/IP Configuration
Comm > Connect. Navigate to OMC: Numbering> Numbering Plans> LAN/IP Configuration
Comm > Connect. Navigate to OMC: System Miscellaneous > LAN/IP Configuration
*21. Where is possible to know the available license in the OmniVista 8770?
Help > About
Applications > License
Help > About >License
Windows >License OmniVista
*22. The Topology application allows users to display and monitor operation of:
- OmniPCX Enterprise, OmniPCX Office and OpenTouch™ nodes
- Links between OmniPCX Enterprise and/or OmniPCX Office and/or OpenTouch™
nodes
- Sensitive applications
- Networks and subnetworks
nodes
nodes
*23. What is possible to affirm ?
The Passive Communication Servers are not managed by the Topology application.
Only Alarms for which the system can detect a beginning and an end, are displayed in Topology screens.
The Topology license do not must be present in the license list displayed only the
Alarm license that already includes both modules
The answer “c” is false
*24. There is no specific license for the Report application. However, reports can only be generated from applications for which you have access rights. Is it?
True
False
*25. Reports can be based on detailed or cumulated data. The purge period is different for the two types of data. Then is possible to affirm …
The reports have a maximum storage time of 2 months
The data for the reports will be lost after 2 months
the data from the detailed Traffic Analysis will be purged by default after 45 days while the same data cumulated in daily tables will be purged after 94 days.
As a consequence, a report for last month (example) based on detailed data can be incomplete while the one based on cumulated data will be complete.
The period for rescue data to the reports do not is exact
The storage period for the report depends on the data type.
*26. It is possible to affirm:
When there is not sufficient drive space, reports are no longer generated
The supported browsers to view HTML reports are IE 9, Firefox 12 and Chrome 44
Three tabs are required to update templates: Property, Querytool and Designer.
When fields are selected in the Querytool, the "Not empty" filter do not must be added, otherwise empty lines may appear at report generation.
*27. It is possible to affirm:
Alarms are transmitted in real-time. A synchronization never is required.
Alarms are retransmitted after a communication server synchronization.
Passive Communication Server (PCS) alarms are not managed by the Alarms application.
By default event reception from a PCX is enabled. So, you must enable the OMC or mgr depending on the type of PABX.
The Alarm and Event trees are manually constructed with the alarms and events received by the alarm server.
*28. It is wrong to affirm:
Notification Date is Date and time at which the alarm was generated
Reception Date is Date and time at which the alarm or event was received by the alarm server
Notification/Reception Date is Date and time at which the alarm was generated/received.
The Maintenance application provides all current maintenance tasks for OmniPCX Enterprise and OmniPCX Office
No license is required to access the Maintenance application.
*29. The Maintenance application allows:
OXO - Backup and Restore; OXE Backup, Restore, Software update and Software update status; PCS - Software update and Software update status
OXO - Backup; OXE Backup, Restore;
*30. The backup storage location can be changed. What is the default location for the backup OXE?
\8770_ARC\OXEBackup
\8770\OXEBackup
\8770_ARC\user\OXEBackup
\8770_ARC\Backup\OXEBackup
\8770 \Backup\OXEBackup
*31. It is possible to affirm:
It is possible to program the keys of digital and IP terminals OXE via graphical interface.
It is possible to program the keys of digital and IP terminals OXE only users tab.
There is no way to program the keys of digital and IP terminals OXE unless the user tree in larger screen table after selecting the desired user;
It is possible to program the keys of digital terminals OXE via graphical interface.
It is possible to program the keys of digital and IP terminals OXE only users tab via mgr.
*32. What happens if the password swinst user is registered incorrectly?
It will be impossible to change user settings
It will be impossible to make the modification keys of digital terminals
It will be impossible to do any maintenance level administrator in OXE
It will be impossible to change the OmniVista alarms settings
Anything. The password is only important to the user mtcl
QUESTIONS ABOUT ALCATEL 8770
Re: QUESTIONS ABOUT ALCATEL 8770
where are these questions coming from?
Br
rolfo
Br
rolfo
- cavagnaro
Customer I guess and they willing to sell Omnivista... If you don't have an expert how you expect to deploy this?
It looks more a test quiz.
Enviado do meu ALE-L21 através de Tapatalk
Hello all,
I really doubt that these questions come from a customer.
If a customer really has the knowledge to create questions like these, it is pretty clear that the customer already knows the answers.
Additionally, in all my life of answering tenders for customers I have never seen a question catalog of this style.
There is one thing, which wonders me: I cannot remember any of these questions being part of an ALE exam like the ACFE 8770.
@RMENEZES: If you share your thoughts of the correct answers then I am pretty sure that the community will be willing to help you but just dropping a test of 32 questions in here is not the way to go.
Br
rolfo
Br
rolfo
These are questions out of the ACFE test!!!!
- cavagnaro
Lol, what a... D...hate those guys who prefer someone else to answer their tests instead of studying
