Good Morning. Can you help me in this problem?
i was forced to reinstall Omnivista 8770 R2.6.05.01. The installation was done without problems well then i lift up backup. At the time of lifting services at the end of the restoration this failure. i checked in the restore context Suffix, Domain, Version and NMCname also i install all patch.
the error is:
8770VERSION_MISMATCH
Accion Failure
thx for attention.
Restore Backup "Accion Fail"
- cavagnaro
Re: Restore Backup "Accion Fail"
Version mismatch... You are restoring a backup of a different version of what you have installed
thx you cavagnaro but i review the version its the same at the restorecontext.ini. same version, same windows, same CPU. but the error is persist
I have the same issue in version 2.6.07.01. Did you fix the problem?
