Dear All, Is it possible to make a connecteur with ldap 8770 and active directory
export telephon number to ad
if you have doc
thanks
8770 and AD windows
Re: 8770 and AD windows
yes, it is.
regards...
Gesendet von iPhone mit Tapatalk
regards...
- cavagnaro
Hey tgn
What did he means? To insert number from AD by reading it? If so, how?
synchronization of OmniVista Company Directory with Microsoft AD is supported (and officially only with MSAD).
You can sync it by mapping the attributes (e.g. Last name in 8770 corresponds to sn in MSAD) and the directions how they are synchronized.
The thing is, you need to have a license called External Directory Synchro.
Br,
rolfo
Br,
rolfo
i think he means the other way -> to insert a number from 8770 into AD. i have programmed such a thing some times ago. i was a little bit different (since it sync from AD to 8770). it needs just customization.cavagnaro wrote:Hey tgn
the MSAD tool inside the 8770 maybe do the same, but it's a little bit too much alcatel-"magic"-thing for me...
regards...
Thanks tgn
i m agree with you
do you have any docs about.....
i m agree with you
No special Docs.
The LDAP Fieldnames of 8770 Directory are described in the 8770 Adminmanual (8AL90703USAI).
regards...
We want to integrate all users of omni vista 8770 in one go with MSAD. The problem is to Copy and paste primary link for each user individually. Can you please guide me how can we update primary link of all OV user in MSAD automatically?.rolfo333 wrote: ↑06 Sep 2017 12:33 Hello,
Br,
rolfo
Regards.
Omniswitch image for GNS3
Hello
I need Omniswitcch image file to run on GNS3 software. It is required for my master thesis.
Can you share me a link?
Thanks for your interest
