OS: windows server 2012 R2
I ran the setup as administrator
Log:
OV8770 FinalizeSetupProperties 14:55:16: ============================================================
OV8770 FinalizeSetupProperties 14:55:16: Opening MSI database
OV8770 FinalizeSetupProperties 14:55:16: Reading .ini file: C:\Users\isbel\AppData\Local\Temp\{ED25DF56-9ECA-4ECF-AD07-48394B831309}\8770_Setup.ini
OV8770 FinalizeSetupProperties 14:55:16: Setup mode: upgrade
OV8770 FinalizeSetupProperties 14:55:16: *** Set properties according to LDAP values.
OV8770 FinalizeSetupProperties 14:55:16: Reading replacements from C:\8770\etc\replacements.properties
OV8770 FinalizeSetupProperties 14:55:16: Service DirectoryServer7-1: stopped
OV8770 FinalizeSetupProperties 14:55:17: Error: DirectoryServer7-1: service control failed
OV8770 FinalizeSetupProperties 14:55:17: exit code: 1603 (failure)
OV8770 FinalizeSetupProperties 14:55:17: Closing MSI database
CustomAction NmFinalizeSetupProperties returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 14:55:17: NmFinalizeSetupProperties. Return value 3.
MSI (c) (80:AC) [14:55:17:291]: Doing action: SetupCompleteError
Action 14:55:17: SetupCompleteError.
Action start 14:55:17: SetupCompleteError.
Does anyone know what could be the reason?
Upgrade OV8770 R2.5.04 to R3.0.13
- knightrider
Re: Upgrade OV8770 R2.5.04 to R3.0.13
When you say you ran as admin... did you use a domain admin account or the original local machine admin account? Domain admin accounts have caused me many problems with OV8770
I used a local admin account.
- knightrider
Have you tried stopping that DB service yourself manually before you run the setup?
The DB stopped when i ran the setup. Now I can't start the service even restarting the system.
- knightrider
hmmm not sure why that has broken in that case. Sometimes it's just easier to follow a migration process using the migration tool and then Install R3 fresh and import the migrated data.
I have a snapshot of the vm. I solved updating R2.5 to R2.6 and then R2.6 to R3.2
Thanks for your answers!
