omnivista 8770 "cannot connect to server"
This application replaces the OmniVista 4760
syedatif
Post by syedatif »
If I close omnivista 8770 and try to open it within 5 min it will give error server is initializing do u want to wait after that it will give error "cannot connect to server"..then again I have to reinstall OV8770 .At list i have to wait 15 to 20 min to normally open 8770nmc...Please some one help me...
rolfo333
Re: omnivista 8770 "cannot connect to server"
Post by rolfo333 »
maybe the 8770 services on the 8770 server are not started properly.
Check if you find several services on your Windows machine which starting with NMC in the name (16 all together).
Maybe just a simple reboot of the server helps then or you can restart the service named NMC Service Manager.
Br,
rolfo
syedatif
Post by syedatif »
Restarted "NMC Service Manager" still same problem..Attached files.. first it tells "Server is initializing" if i click on yes it will take 10 min and again same message comes if i click no then the second dialog box come. "Unable to connect to server:
alexeik
Post by alexeik »
show a screenshot of all NMC services...
HUSSAINQCS
Post by HUSSAINQCS »
Have you tried reboot as rofol suggested
syedatif
Post by syedatif »
Thanks for your support.. as you said services was not running so i reinstalled NMS and now it is working fine...
mustafa.ahmad
Post by mustafa.ahmad »
can u please advise , how did you reinstall NMS , or do u mean OV 8770. as this is quite a common problem
mdhussainvlr
Post by mdhussainvlr »
There is a uninstall tool from OV 8770 run that after restart your PC then you start fresh installation
morio
Post by morio »
through out the years i have been facing this problem and still ALE dont have a proper solution. i have a server where its giving me the same problem. as for me i can not reinstall it as i dont have a 8770 back up.
for those who can help me ,, i see in the services i see NMC service manager running but all other 15 NMC services are in manual and not started.
any recommendations please,,,
Return to “OmniVista 8770”
