Can't open topology and alarms
This application replaces the OmniVista 4760
alhmami
Post by alhmami »
When I'm trying to open topology or alarms it shows me (http error 404 not found).
if any log required tell me how to collect it and I will share it.
Thanks a lot.
doublezero
Re: Can't open topology and alarms
Post by doublezero »
Which Version do you use? When it is 3.2 check wildfly service is running and when not check which service use port 8080
Besteht regards
Gesendet von meinem A0001 mit Tapatalk
ACFE OXE R11.1 | ACSE OpenTouch R2.0 | ACSE 8770 R2.5
oldboy
Post by oldboy »
permissions on IE
agurain
Post by agurain »
oldboy wrote: 05 Dec 2017 23:12 permissions on IE
I havethe same trouble... wich permissions on IE???
fery_s
Post by fery_s »
I have the same problem, i'm trying to open topology and alarm tab in my 8770 release 3.2.08.07 client and get http 400 error.
did anyone solved this issue?
alex
Post by alex »
Try with 3.2.08.10 and the latest patches
Return to “OmniVista 8770”
