unable to install omnivista 8770 r3.2
This application replaces the OmniVista 4760
ssheriff88
Post by ssheriff88 » 07 Dec 2017 04:14
during the installation of omnivista 8770 i am getting an erro as SSl failure
doublezero
Re: unable to install omnivista 8770 r3.2
Post by doublezero » 10 Dec 2017 08:12
Which Version of 3.2 there are 3.2.7 and 3.2.8
Without installlog it is hard to help
Did you use an local account
Are the IP addresses fixed
Are the fqdn of the server has no special characters
Is anti virus toool switched of during installstion
You can also contact ale support with ESR to assist you
Gesendet von meinem A0001 mit Tapatalk
ACFE OXE R11.1 | ACSE OpenTouch R2.0 | ACSE 8770 R2.5
fery_s
Post by fery_s » 12 Dec 2017 05:01
i had this issu too ,this error caused by windows service pack , just install windows server 2012 sp2 or 2008 sp2 and problem must solve
EsraHassan
Post by EsraHassan » 06 Sep 2018 03:46
I installed Omnivista 8770 on windows server 2012 standard R2 without service pack and it stopped working giving unable to connect to server error when open the client, IS not installing SP
Return to “OmniVista 8770”
