LDAP / Directory Listing
This application replaces the OmniVista 4760
mgsox
Post by mgsox » 11 Jan 2018 07:03
hi all
my customer made a penetration test on their network and ask me to disable LDAP NULL BASE Search Access and Directory Listing from 8770.
does any one know if it is possible to do so? and if yes how can i do it?
also it is possible to connect to 8770 using web browser ( normal behavior) can i disable it too?
thanks for your help
Re: LDAP / Directory Listing
Post by tot3nkopf » 11 Jan 2018 09:35
Block the ports on Windows Firewall?
mgsox
Post by mgsox » 12 Jan 2018 04:40
thanks for the answer.
i thought of that but the customer does not want it that way!!
i did not find any other solution either so i think i go with that
Post by cavagnaro » 12 Jan 2018 11:10
If you can't access via Web, then how?
Return to “OmniVista 8770”
