8770 tax column
This application replaces the OmniVista 4760
morio
8770 tax column
Post by morio » 05 Feb 2018 14:01
hi guys, need some help with 8770 reports. everything works fine till the client ask to add a tax column for each out going call. i have seen the predefined report with the tax column, but when i generate the report, the cos with tax and with out tax is the same. where do i add the % of the tax?
please advice,,
thanks in advance...
Re: 8770 tax column
Post by haroun » 08 Feb 2018 06:52
i'm reasoning on 4760 cuas ehaven't 8770 , should be same or similar , tax should be added under accounting module . under parameter/carrier/taxe
morio
Re: 8770 tax column
Post by morio » 11 Feb 2018 09:04
Hi. Thanks for your reply. I have done that but still the same. I will get some capture for reference and give you a feed back.
Thank you
morio
Re: 8770 tax column
Post by morio » 14 Feb 2018 02:36
hi haroun,
i have tried but i get the cost with tax equal to the cost of with out tax
please check the two attachments, i have even done a compute cost as well
hope to get a positive reply...
thanks till then
alex
Re: 8770 tax column
Post by alex » 14 Feb 2018 09:17
Do you have tax in your Carrier/Period/Tariff defined?
morio
Re: 8770 tax column
Post by morio » 15 Feb 2018 06:45
Hi..
In the tariff it's not. Can I add it. If so please explain how.
alex
Re: 8770 tax column
Post by alex » 15 Feb 2018 07:53
So in Carrier/Period/Tariff definition you have TAX line. Just click on empty line and it will show taxes defined, choose yours and save, do cost recalculation after.
Return to “OmniVista 8770”
