De-allocate an extension number
This application replaces the OmniVista 4760
Sysadmin2317
Post by Sysadmin2317 »
We have one problem phone (Alcatel 4028) which we cannot log out off. Normally we would hit *79 to log out so we can swap extensions.
Currently when we hit *79 and enter the secret code, I get "feature rejected".
Is there a way I can do this in the 8770 console?
Thanks,
Re: De-allocate an extension number
Check if his phone category allows him to do that.
Also, your PBX is not 8770, that is just the management system.
You maybe have an OXE or OXO
alexeik
Post by alexeik »
delete the mac-address in tsc ip user under users.
alex
Post by alex »
alexeik wrote: 04 May 2018 10:11 delete the mac-address in tsc ip user under users.
Quite a radical solution.
OP seems just want to log out from a hunting group or from an ACD group.
To Sysadmin2317: From where you want to log off that user?
alexeik
Post by alexeik »
he wrote he want to swap extensions, so i thought *79 is set in/out of service
Return to “OmniVista 8770”
