Stacking on 6900
preawss
Stacking on 6900
Post by preawss »
If i want to use stacking feature, Must I buy license addition ??? or I can use this feature by not purchasing license
thank you
Re: Stacking on 6900
Stacking at 6900 is virtual Chassis (VC). And you need the advanced routing license for it.
dogx010299
Post by dogx010299 »
Dear Sir,
I have a question about VC too.
From my scenario, I have HQ and Branch Office.
They are too far away, so I can only use L2 VPNs, for example VPLS or L2TP.
Can my OS6900 run VC across L2 VPNs ?
Thanks.
Best regards,
Andy
No, this doesn't work. The VFL = virtual fabric link between two stack members must be fibre 10G or 40G.
Return to “OmniSwitch 6900”
